FOXEER LEGEND 3: 4k/30 Ambarella A12S75 / Sony IMX117 1/2.3 Inch 12MP - ANY GOOD FOR DASHCAM?
Discussion in 'Foxeer' started by dirkzelf, May 28, 2017.
  1. Dashmellow
    Dashmellow Well-Known Member
    8,324
    8,392
    Uncanny Valley (●_●)
    Country:
    Dash Cam:
    SG9665GC, Mobius/M2 (x7), GT680W (modded), DR32, others
    My understanding is that the ability for a camera to operate off a super-capacitor is simply a function of how the firmware handles the shutdown/filesaving procedure. I'm sure @jokiin can verify if that notion is correct.
    That's basically what I learned when I spent months experimenting with installing super-capacitors in a camera not designed for it. So, for example, if you flash a G1W camera with firmware from the G1W-C you can get the G1W to work with super-caps instead of the battery pack.
  2. dirkzelf
    dirkzelf Active Member
    640
    194
    Country:
    Netherlands
    Right, that is also how I always got that, so it's a firmware thingie, no need to change anything on the pcb.
    Then why would Foxeer say that???
    The only thing I can come up with is maybe because then they would want to use another connector?
  3. Dashmellow
    8,324
    8,392
    Country:
    Dash Cam:
    This seems like a very cool camera with a lot of potential. It's a shame that it is not optimized for use as a dash cam.
    I don't understand Foxeer's marketing logic since it would open up a whole new sales opportunity for their cameras without having to do much to make it happen.
    dirkzelf likes this.
  4. dirkzelf
    640
    194
    Country:
    Netherlands
    Yeah, I try to make that clear to them every chance I get, but it would seem they just don't see it, or just don't care?
  5. Dashmellow
    8,324
    8,392
    Country:
    Dash Cam:
    :grumpy:
  6. dirkzelf
    640
    194
    Country:
    Netherlands
    makes me :cry: too
    why don't the see the :greedy:??
    Dashmellow likes this.
  7. SawMaster
    SawMaster Well-Known Member
    2,532
    2,089
    SC
    Country:
    Dash Cam:
    Mobius, G1W-S, G1WHc x2, G1W clone, and more to come!
    JooVuu was designed from the start this way. Mobius did have to alter the circuit to make caps workable, but they did this early in production- the oldest versions of Mobius can't use the cap conversion while most versions can. From my understanding it is not a tough thing to do for a manufacturer which is why I can't understand that it's not happening :(
  8. Dashmellow
    8,324
    8,392
    Country:
    Dash Cam:
    I have a first generation V1 pcb Mobius that works fine with super-capacitors.
    russ331 likes this.
  9. SawMaster
    2,532
    2,089
    SC
    Country:
    Dash Cam:
    Could be just be my aging memory then, but I was sure that there was a board change made when the cap conversion came out. Too bad a new SD card can't fix my brain's memory :rolleyes:
  10. Dashmellow
    8,324
    8,392
    Country:
    Dash Cam:
    :D
  11. jokiin
    jokiin Well-Known Member Manufacturer
    34,492
    17,124
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    that's a large part of what's needed and will get you the basic functionality, it also needs an RTC cell if you want to keep time/date settings beyond a few days, the Supercaps (and RTC if used) also need an appropriately designed power circuit to function correctly, the design to suit a battery installation is not always ideal but can sometimes work
  12. Dashmellow
    8,324
    8,392
    Country:
    Dash Cam:
    Thanks. Interestingly, the Mobius keeps the date and time for a week to ten days without an RTC cell. Then again, the camera has no screen, beeps or other current draining functions found on other cams.
  13. jokiin
    34,492
    17,124
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    a lot of the things the Mobius does better than others come down to how simple it is, not always a good thing to have all the bells and whistles
  14. Dashmellow
    8,324
    8,392
    Country:
    Dash Cam:
    The longer I've owned and used dash cams the fewer bells and whistles I want. Image quality and absolute reliability are what I'm after. Maybe add a screen, logical menu tree and a good mounting scheme and I'm happy.
    harsh, SawMaster and Gabacho like this.
  15. jokiin
    34,492
    17,124
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    yeah unfortunately that's something people often don't find out until after they've bought into the marketing spiel of the 'latest and greatest'
    SawMaster, Gabacho and Tobi@s like this.
  16. kamkar1
    kamkar1 Well-Known Member
    12,924
    6,343
    Country:
    Denmark
    Dash Cam:
    Lukas LK-7500G / Innovv C3 / mobius / G1W / SG9665GC & more
    I really like to see some footage from the 4K CCTV cameras out there, without IR aid for night footage.
    BUT ! if its still the same small sensors then i doubt it even if the sensor are just 8 mpix, but if they upped to sensor size to accommodate bigger pixels, than that would be nice.
    with the IMX 117 in there, night time footage will not be stellar by a long shot, but if you can make do with lights ( head lights - rear lights - street lights - intersection lights and if there lane markings, then you could make do )
    I did say in the SJ7 sub forum i could make do with the performance of it for night dashcam footage, but i also have a rather special point of view on night performance.
    So yeah a IMX 291 camera will see a lot more, but really that more are not really that useful as documentation, so you are left with those dawn and dusk times where the IMX 291 off course will work a little better as light fade in or out.
    On the other hand while it is to the bone footage from a IMX 117 sensor, then you still do get all the big things logged, but peripheral view will be 0 compared to IMX 291.
    Off course you should go for a IMX 291 camera, but in a pinch i would not feel too bad putting a IMX 117 camera in the windscreen.
  17. dirkzelf
    640
    194
    Country:
    Netherlands
    OK guys, thanks for the input about the supercaps thingie, so I conclude that Foxeer may be correct about needing to change the board.... thats a bit of a dissapointment, but....
    you know me, I'm gonna try anyways....
    I've asked for a loose battery connector so I can try with one of my Mobius or Joovuu X cap..... and a set of top/bottom housing to make a "cool" version. I'm gonna try a micro fan as well. (Remember my modded L2? https://dashcamtalk.com/forum/threads/foxeer-legend-2-beta-f-w.20893/#post-277273)
    Fingers crossed... Wish me luck!
    (don't expect a report soon, I dont have the parts yet, nor the scematics, but I will try get it all)
  18. dirkzelf
    640
    194
    Country:
    Netherlands
    I just got my 4k L3, but the IR filter stays ON ..... well, for now....
  19. kamkar1
    12,924
    6,343
    Country:
    Denmark
    Dash Cam:
    hehe it is the more cctv dedicated sensors i am interested in, if i wanted to see IMX 117 i could just put another lens on the SJ7 in a few minutes.
    I do believe i saw some Sony 4K starvis sensors.
  20. dirkzelf
    640
    194
    Country:
    Netherlands
    Nice...
Loading...
Share This Page
