FoxOffer Dome G90 Dashcam Review - A7LA30, OV4689 CMOS
I can tell that this is not the case, i just checked that through HDMI cable directly and same problem persists with sound.
Microphone is very sensitive and it can hear weak sounds from outside of car, but even if your radio is at normal volume level it breaks sound.
Does Billknow knows what is this problem with sound and can it be adjusted?
Personally i don't mind but it would be nice to have clear sound. And yes, my G90 is from foxoffer if you wondering.
Does @Doreen know this? I think you know much more than me.
hello friends, I am here today 😉 sorry during these days I was busy that did not have time to log in DCT.
if you want a quicker reply from me in future, please send an email directly to me dome.doreen@gmail.com
well, regarding the sound problem, this was the problem of the first batch, from the second batch, there is no such problem.
please inform me the firmware version number of G90 on your hand, I'll send the updated firmware to you.
Doreen,
could you post a link where I can get the ambarella A7LA70 version ?
This A7LA70 version should be capable of 1080p@60fps .....am I correct ?
is the Ambarella A7La70 version available in your website or in aliexpress ??
Thanks Doreen, I've updated and now have r328MP installed - are there any other fixes with this firmware at all please?
Doreen, is the Ambarella A7La70 version available in your website or in aliexpress ??
I need 1080p 60fps.....
Any ideas on price yet please Doreen for the new one?
G90 with A7LA70 will be available soon, within 1-2 weeks.
so I guess the info I was provided previously was more accurate than you suggested 😉
interesting as they've been saying samples of this model aren't going to be available for another month yet
Is there a way to figure out if HDR is on or off by looking at the file properties?
I never noticed anything - easiest way was to look closely at lights to see and if you freeze frame street lights as they get close if HDR was on you get duplicates where the HDR hasn't merged the frames correctly. I get the same behaviour on the LS460W so looks like they're also trying to do something clever in firmware and failing.
Not sure whether these Street Storm mounts would work with the G90 but there are four options here:
http://www.streetstorm.ru/catalog/videoregistratory/
No GPS:
http://www.streetstorm.ru/catalog/videoregistratory/CVR-M1/
http://www.streetstorm.ru/catalog/videoregistratory/CVR-M2/
With GPS:
http://www.streetstorm.ru/catalog/videoregistratory/CVR-M1G/
http://www.streetstorm.ru/catalog/videoregistratory/CVR-M2G/
If I was a betting man I'd say the CVR-M2 and CVR-M2G have the best chance of working as they're for the CVR-7810 (-G) which are the same base hardware platform.
Not sure if there are any other mounts you can buy which might fit the G90? One for @Doreen I guess.
Here's how the custom firmware running at 24Mbps VBR compares to the LS460W at 15Mbps CBR.
Well I had a spare 30 mins so made a custom firmware using @Tobi@s A7Tool which runs at 24Mbps VBR, with a min of 1 and a max of 2 to let the bitrate fluctuate as it needs. The videos have come out great IMHO.
Hmmm... The screenshot with the mini cooper is definitely different as one is clear and the other is in motion.
May be due to difference in VBR?
What's the difference in video quality G90 vs G90 with custom firmware?
Also, does running at 24mbps affect G90 in adverse way? I mean overheating, skipping etc?
What about video file size?
Any improvement in audio?
If everything looks good, I can also upgrade in the future.
thanks
thanks
The LS460W has issues with motion close up from what I've seen - they seem to be keeping the exposure levels high to keep the picture brighter in harsher conditions at the expense of sharpness.
Unfortunately I can't directly compare as only have one G90 so you can do those tests yourself if you just do the same run twice in quick succession so the lighting etc is similar 🙂
The G90 gets hot but you'd need to do longer term testing to see how stability is - I ran it for an hour with no issues and to be honest it wasn't that hot to be honest and it's about 26 celsius here outside.
In terms of sizes you're looking at the following:
Code:
01/01/2008  00:47       209,780,736 2008-01-01-00-46-46.MOV
01/01/2008  00:48       230,752,256 2008-01-01-00-47-46.MOV
01/01/2008  00:49       230,752,256 2008-01-01-00-48-46.MOV
01/01/2008  00:51       230,752,256 2008-01-01-00-50-46.MOV
01/01/2008  00:52       209,780,736 2008-01-01-00-51-46.MOV
01/01/2008  00:20       209,780,736 2008-01-01-00-19-59.MOV
01/01/2008  00:21       230,752,256 2008-01-01-00-20-59.MOV
01/01/2008  00:22       251,723,776 2008-01-01-00-21-59.MOV
01/01/2008  00:23       209,780,736 2008-01-01-00-22-59.MOV
01/01/2008  00:24       209,780,736 2008-01-01-00-24-00.MOV
01/01/2008  00:26       188,809,216 2008-01-01-00-25-00.MOV
01/01/2008  00:27       209,780,736 2008-01-01-00-26-00.MOV
01/01/2008  00:28       209,780,736 2008-01-01-00-27-00.MOV
01/01/2008  00:29       230,752,256 2008-01-01-00-28-00.MOV
01/01/2008  00:30       209,780,736 2008-01-01-00-29-00.MOV
01/01/2008  00:30       104,890,368 2008-01-01-00-30-00.MOV
01/01/2008  00:31       230,752,256 2008-01-01-00-30-44.MOV
01/01/2008  00:32       230,752,256 2008-01-01-00-31-45.MOV
01/01/2008  00:33       209,780,736 2008-01-01-00-32-45.MOV
01/01/2008  00:34       230,752,256 2008-01-01-00-33-45.MOV
01/01/2008  00:35       230,752,256 2008-01-01-00-34-45.MOV
01/01/2008  00:36       251,723,776 2008-01-01-00-35-45.MOV
01/01/2008  00:37       230,752,256 2008-01-01-00-36-45.MOV
01/01/2008  00:38       230,752,256 2008-01-01-00-37-45.MOV
01/01/2008  00:39       251,723,776 2008-01-01-00-38-45.MOV
01/01/2008  00:40       230,752,256 2008-01-01-00-39-45.MOV
01/01/2008  00:41       230,752,256 2008-01-01-00-40-46.MOV
01/01/2008  00:42       251,723,776 2008-01-01-00-41-46.MOV
01/01/2008  00:43       230,752,256 2008-01-01-00-42-46.MOV
01/01/2008  00:44       230,752,256 2008-01-01-00-43-46.MOV
01/01/2008  00:45       209,780,736 2008-01-01-00-44-46.MOV
01/01/2008  00:46       209,780,736 2008-01-01-00-45-46.MOV
01/01/2008  00:50       230,752,256 2008-01-01-00-49-46.MOV
As you can see it's hitting almost 250MB per minute so you'd get around 32 mins on an 8GB card at that rate so working that out:
8GB - 30mins
16GB - 1 hour
32GB - 2 hours
64GB - 4 hours
Audio is better with the latest firmware that Doreen supplied but still has clipping - if the mic was bad in the first batch then there's only so much they can do to polish a turd 🙂
I think it's fair to say the G90 is punching above it's weight!
