I'm sorry but one of your own diagrams illustrates the problem, with a 30A fuse leading to the original load and a 5 A fuse leading to the PMP. Meaning the combined current could be 35A from the hot feed.Both ways are "safe" one is not "safer" than the other.
Yes, the original devices are protected as before. But some of the wire leading to the fuse box is less protected than before, if the fuse tap is fitted a certain way.the original circuit is protected regardless of which way the tap is installed
Fuses are there for when things go wrong, not for when things are working as planned. If you tap into a 10A fuse then it is quite likely to be supplied by 10A wire, car manufactures don't put unnecessary copper in the cars as it reduces profits, use a 10A fuse for your new circuit with the tap the wrong way around then it is possible to draw 20A down the 10A wire. Just needs your lithium battery to short out internally while you are using the thing the circuit was intended for and you might have smoke and maybe flames.if you overload a circuit of course you could damage it, unlikely with just a camera and providing the correct size fuses are used, but still something to keep in mind
The consequences of a car fire can be very nasty, why take any chance, however small, when you can very easily put the tap in the correct and safe way around? It doesn't cost any extra to put it the correct way around, it is not difficult, but it is safer.
They are very safe if used with a correctly installed and rated fuse!if nothing else you've finally admitted lithium batteries aren't safe
would depend what you wanted to add but I can't see people really adding too much extra equipment for that to become a problemHow many add-a-circuits can you safely use in the fusebox?
Thanks for the response. We are working on temporary solutions for rear cameras, and our installer advises to put them on separate circuits and not to exceed three. He does not enjoy my complete confidence so I am looking for other opinions.would depend what you wanted to add but I can't see people really adding too much extra equipment for that to become a problem
My suggestion would be to use 1 fuse tap on the accessory fuse and use it to power 1 decent quality multi way USB converter such as:Thanks for the response. We are working on temporary solutions for rear cameras, and our installer advises to put them on separate circuits and not to exceed three. He does not enjoy my complete confidence so I am looking for other opinions.
Things do get out hand sometimes
Me too but did not know how / where to find such a fine example. Well done..first thing that came to mind
You might need to alternate the orientation of the fuse taps. I.e. the 'output' of one fuse has to feed the 'input' of the one above to get the effect you describe.You could add as many as you can fit. Providing you keep the hot side common to all you could even stack one on top of another. Each subsequent fuse tap would be limited to the size of fuse under it.
Since in most fuse taps, the fuses go at 90 degrees to the originals, you will have to alternate them or they will not physically fit!You might need to alternate the orientation of the fuse taps...
The whole concept of adding multiple fuse taps is silly . Use ONE.. and add as many outputs as you like from that ONE pigtail. Add an inline fuse on each leg if you want extra safety.. but it would not be necessary.They will also build up in a staircase instead of vertical making it difficult to use taps in the adjacent fuses and the stack will probably become rather unstable!
