pentavalle
- May 27, 2016
- Italy
Cant' download from that dropbox link, it says there's an error trying to download... Why isn't it present in official gitup website?
It can not support 1440P 60fps.Hi @gitup, any hints on what the 1.7 firmware will fix and/or improve upon? Do you know if the chipset can support 1920x1440 @60fps?
It is digital zoom, this option does the crop of full image from sensor. I didn't find any option to change zoom on the go. So, you can set it only via Video settings.Anyone:
How does the zoom work? Pressing the shutter button while filming?
I've never used the Narrow POV option in the earlier firmware releases, but I thought it might be useful to decrease the amount of fisheye. Do you think the Zoom function is effectively the same (but with more settings)?It is digital zoom, this option does the crop of full image from sensor. I didn't find any option to change zoom on the go. So, you can set it only via Video settings.
Available values are in range from 1.0 (no zoom) to 2.8. Digital zoom affects on image quality and doesn't work with gyro on.
With 2.8x zoom an object in the original image will appear 2.8x the height in the zoomed image so you will have 36% of the original FOV.I wonder how many degrees of the FOV is cropped by the 2.8 zoom maximum range
i have used the narrow setting for that exact purpose. i was filming the installation of an FPV camera to a micro drone, with the camera attached to my desk lamp with an elastic band, pointing straight down at my desk. wide angle showed way more than necessary, and even narrow was still kinda wide, but it worked out, in that i only had the camera about 1.5ft above my desk and it still showed the work area i wanted it to.I've never used the Narrow POV option in the earlier firmware releases, but I thought it might be useful to decrease the amount of fisheye. Do you think the Zoom function is effectively the same (but with more settings)?
Bit disappointing it doesn't work with the gyro on, on the Git3 it works fine and turns the camera into more of a camcorder rather than a wide angle action camera with fisheye, this was recorded with a zoom of x2.2:It is digital zoom, this option does the crop of full image from sensor. I didn't find any option to change zoom on the go. So, you can set it only via Video settings.
Please take a look at 6-7 sec with more attention at backside treesBit disappointing it doesn't work with the gyro on, on the Git3 it works fine and turns the camera into more of a camcorder rather than a wide angle action camera with fisheye, this was recorded with a zoom of x2.2:
Yes, I had noticed, not sure what caused that, maybe the WDR which was turned on? Haven't seen it before, and this is still a prototype with frequent firmware changes.Please take a look at 6-7 sec with more attention at backside trees
The stable V1.7 version is now available at:Be aware. Some users report about corrupted files in 1080p30 mode with 1.7 firmware.
Stable version 1.6.1 for Git2 (Sony sensor) is available at site: http://www.gitup.com/content/8-how-to-upgrade-the-firmware-for-gitup-git2-and-git2p
