An alternative is to use a fuse adaptor like this: https://www.amazon.com/gp/B00SUX9V4KI have a general question.
I bought rexing hard wiring kit (I went with that because it comes with angle/elbow USB connector), it has a fuse (15A) attached to the red wire.
Can I simply remove an existing fuse and install this there to get the power? Or do I have to use an empty slot?
Ground is readily available, there is a bolt that we can use.
At first I want to use a switched power, later I want to upgrade to constant on and use low voltage protector in between.
Any suggestion/guidance would be extremely helpful and appreciated.
Thanks everyone.
It appears that some clarifcation is required concerning fuses, and what to use.
The first point is, a fuse is put into a circuit to protect the cable following it NOT what is connected at the end of the cable. If what is connected to the cable needs protecting it should include local protection.
Secondly, there are many types of fuses all with different characreristics. The most common type is the wire fuse. This will carry the rated curent indefinately and will fuse at twice the rated currently immediately. At currents between rated and twice the fusing time will decrease to zero at twice the rated current.
The hardwire kit for my Blacksys includes in line fuses. From the pic SJConnor posted it looks like it has it's own fusebox fuse so he may need to find an empty slot if a fuse adaptor won't fit.
Guessing you are connected to a fuse that turns off when the engine is off.. I would think the brake circuit would be a good choice to tie into for an always on source.Thanks, I did my hardwire and it works great, but cam turns off when my car auto shuts off at red light.
Is this a common problem on recent cars that have Auto Start & Stop?
need to find a circuit that remains active when the car shuts off
Thanks, but I don't want it to drain my battery when parked, so I wanted to use switched fuse.
