If I accidentally take off air bag fuse, probably the car will warn me about it using some light when starting the engine? Since it's quite important. And why do you think "setting off" would cause such big bill?Even disturbing an air bag fuse could set them off at a cost of several thousand $$$$.
Anyway, the fuse box does not even have a screw, you can just open it. If there would really be very essential parts there, the car manufacturer would try more to prevent users from opening it.
At least for, G1W, it is 5V. https://dashcamtalk.com/g1w/#SpecificationsAre you all sure the camera runs off 5v as all mine are 12v and dont need a stepdown Just a thought.
throrope, thank you for your idea. I will probably do this, too.
And about the black wire thing. It just confuses me to just plug it into a bolt. For example when you plug a LED into battery, then there goes two wires, one to + and one to -. And when plugging LED Strip into adapter - there is two wires, too. But now I should just put the wire into a bolt which goes nowhere, just the car chassis. That is what confuses me.[/quote]
