Hi guis,Need Help.My gitup F1 Stuck in Boot Logo.
Backdoor.X
Bucharest
Romania
Hi guys,I need some help for my Action Camera Gitup F1.is almost 1.5 yeras old.Wich seems to be unusable anymore,camera has start problems.The first problem come when i try to start wi-fi from camera menu,wich is not start even if i enable,this is wierd and after a while,when i try to turn on camera is stuck on boot Logo.and i cannot turn off.i have to take out battery and insert again with same results.and if a plug a usb cable in camera got same results,she is start itself in boot logo.Any help would be appreciated! If i put this thread in a wrong area please move to right place,Thanks!
TonyM
Mobius, SG, Viofo
Have you tried reinstalling the firmware? Copy a FW .bin file to the micro SD card, put it in the camera then turn it on.
B
Backdoor.X
Bucharest
Romania
Yes,i also done this,i put FWF1.bin in root microSD(Fat32),and no success.i start camera and is only displayed GitUp.and is staying like this until i take out the battery.i also have no Led blinking red or blue,if i connect a usb cable i hear windows notification sound and camera its not start-up.if i start camera connected with usb cable,is start with full icon battery and both red led light(not blinking).i will try to open camera to take a look inside.Any ideea?Thanks!
TonyM
Mobius, SG, Viofo
I don't think you will achieve anything by opening the camera. If you do, take care not to pull the WiFi aerial off the PCB when you separate the two halves.
Perhaps @gitup can offer some advice to fix your camera
B
Backdoor.X
Bucharest
Romania
I opened the camera, I couldn't find who knows what, but I found this clock Back-up small battery that looks oxidized, I measured with the multimeter and it has somewhere at .0732 mV. And I think it would normally be somewhere at 3.3 V. I unsoldered it and soldered 2 wires in its place where I added the outside current just to do a test, but the result was the same, it started and stayed locked in the Boot logo, the camera being small and compact, with insufficient cooling space, I think that due to overheating, one of these integrated circuits (Ambarella A12 or Chipsip CT49 ...) may have been detached. .When I have more time I will do a reflow to these IC.
