CharlieG
I'm hoping someone can help me, I feel like I have something wrong in settings. This doesn't look like the 4k videos from reviewers on youtube at all.
Take a look at the photos below. Do I have a bad camera or is this what I should expect quality wise? This looks like video from my 2007 canon point and shoot digicam.
This is my first dashcam and I the only 4k comparison I have for video are smartphones and my GoPro, both of which can put this thing to shame. I wouldn't expect this to match that quality, but I thought it would come closer than it does. These stills are from H265 Max bitrate, but the issue is still prevalent in H.264 (i just have to watch the vids in VLC because Viofo's encoding doesn't work on Macs). I am viewing on a 4k screen as well.
The screenshots below were taken in native resolution. I have shots that are both moving and not moving. The shot with the Acura SUV turning close to my hood was taken stopped at a light, and the others is while turning. I am uploading JPG @90% compression, but I also have PNG in the dropbox folder below. They look about the same. The rear camera looks much BETTER than the front (though it's lower resolution). I do not see the noise in the rear that I do in the front.
Notice the noise all over everything, the trees, the car turning in front, the road, grass, everything looks like ISO 3200 at sundown.
Settings and Setup
Dropbox Link to raw files: https://www.dropbox.com/sh/uwprk27nphb4jh6/AAAUhnrktVtGWtTKck2ANOQ8a?dl=0
Stopped
Turning / Moving
Bonus in H.264 with no CPL, looks a bit better but still grainy.
Settings and Setup
- A129 Pro Duo, Hardwired with 3 wire kit from Viofo and installed via fuse taps.
- All connections were soldered and then covered in marine heat shrink. Ground is connected to the body and measures less than 2 ohms to negative battery terminal.
- 128GB SanDisk High Endurance for these shots, also have a Sandisk evo plus in the same size. Both U3 and formatted in the camera. I also tried the SDformatter utility in overwrite mode (gonna DL that footage later today)
- CPL Filters front and back, oriented correctly.
- Max Resolution Front and Back
- H.265 Max Bitrate
- Wifi Off (front video measures at 50 Mbits/sec to be sure)
- Front +1/3 EV, rear 0 EV
- Mounted using included mounts, windshield is not tinted and was cleaned meticulously including a new microfiber and IPA to finish it.
- No WDR
- I can't think of any other settings that would be pertinent
Stopped
Turning / Moving
