- Jan 27, 2013
- Australia
- Too many ĀÆ\_(ć)_/ĀÆ
set like this you have no timer cutoff so it will only rely on the voltage setting to turn off
So is it normal? I mean parking mode with finesafer dont work, right?you hookup the ACC normal (no motopark/fine-multi safer involved)
BAT is hooked up through the motopark fine-multi safer
I tested it on the bench worked good
3 other customers said it works good
others tried but never reported back so assume all is well
Fusebox side:It works just follow directions on last page
My head confused now. Would you tell me a picture schema of it or please draw?? My head so confused now.Correct, Red X2 ACC wire is connected direct to the same ACC wire used on MotoPark Fine Safer. (shared to fuse box)
We no longer have the X2 in stock unfortunately and don't have a sample handy. Maybe @niko would be kind enough to help draw out schematic.
Basically you're adding the motopark fine safer in between the X2 and Fusebox for Ground and BAT only.
X2 ACC bypasses motopark and is connected directly to the same fusebox ACC source the MotoPark Fine safer is using. (two wires to the fuse box ACC connection)
I have yet to hook up the motopark you sent. I am waiting to see if I am still having the issues since moving it to our new car. So far so good. Haven't had the stuck boot screen when I go out in the mornings. Strange that I haven't had an issue yet "knocks on wood" since moving it from our 2014 Charger to the 2015 Challenger. Wired the same way with pretty much the same electronics in the cars.you hookup the ACC normal (no motopark/fine-multi safer involved)
Any new cams from Panorama? Pano X3 with Wifi?
