Michael Jenkin
- May 28, 2014
- Australia
- Australia
- i1000 (A10 and F20 chipsets)
Hi all,
I just purchased one of the i1000 units from ebay:
https://www.ebay.com/itm/131188532840
The unit seems to work ok with one exception - I have it set up with motion detection on and it works as specified without the rear camera connected ie it will stop recording after 5 secs of non-activity. However, with the rear camera connected, it will continue to cycle non-stop, recording for 5 secs at a time. The unit is connected to constant power, if that makes a difference.
Has anyone else experienced this problem? Sorry, I'm at work and don't have access to the firmware version at the moment.
Thanks & regards,
Brian
Hello,
From what I have seen with these units, it seems attaching the rear camera causes all the problems. My unit gets warm when I add my rear camera. When the unit plays up, it is the rear camera that looses footage first.
If the battery is low, adding the rear camera shuts the unit down. Many people report the unit reboot cycling when adding the rear camera (there are some samples of this on Youtube). I personally suspect you have a faulty unit or the battery is not coping. I saw someone with similar issues posted somewhere where he solved the issues by removing and bypassing the battery. Straight power from the car battery only. Makes me think that many of these issues are battery and amps related.
Have you brought this issue to the attantion of the seller on eBay ?
