Hi guys,
Newbie here!
I wonder if someone can help me pleaseeee...I fitted the dr650 2ch into my BMW e70 X5. All worked well for a week and now the rear camera stops working and so does the power magic pro.
If I pull out the power cable and reconnect it from the front camera, the rear camera lights up and starts recording...for a few hours but sometimes only for a few minutes.
The power magic pro shuts down and doesn't come back on unless I switch it off and back on again. I've wired 12v permanent direct to the battery, the ACC using the cigarette lighter fuse and used a ground in the boot.
I'm just baffled as to what it could be. The coax cable seems fine. (I don't think this is the problem as when I pull the power cable out of the front cam n re insert it the rear cam lights up for a while.)
I've also had a brand new BMW battery so I don't think it's that. I've set the power magic pro at 11.8v and 12v to see if it makes a difference but it doesn't.
Has anyone else had the same or a similar problem, or a fix!
Any help would be greatly appreciated.
Newbie here!
