=== UPDATE: this is now resolved ===
Hi All,
I have newly purchased the SG9663DC flashed with the latest v1.35 firmware installed in a Volvo C30 with the hard-wire kit and I am finding inconsistency with the dashcam entering parking mode.
I have identified a constant-live for the yellow battery connector in the form of the rear cargo compartment cigarette lighter (actually missing on this vehicle but present on the Volvo V50 estate with which this car shares almost everything) and I am using the red switched accessory connector on the drivers heated seat.
I tapped into this circuit as it seems something that would never be live without the engine running and did not want to use anything safety related (lighting, power steering etc.) I initially had the ACC connector to the stereo but once this has been switched on it is still usable to some degree with the keys out of the ignition, hence moving the ACC to the heated seat.
I parked the car up last night at about 6pm and the dash cam beeped which I assume this means it had sensed the voltage drop on the ACC and had entered parking mode. The "rec" light continued to blink as I locked the car.
Reviewing the footage today it has recorded in real-time all night to my 128GB Samsung endurance SD card. I assume the memory card filled up and it began to overwrite as the earliest footage I have is from about 03:30am which would be roughly 9 continuous hours at 30fps.
At about 10:00am I see myself approach the car from the rear camera in 30fps where I proceed to unlock it. I reposition the car to perform maintenance work on it (i.e. started the engine briefly) then left with the keys in the ignition only to stop it automatically locking or setting the alarm off as I placed it on axle-stands.
From this point onward it appears to have correctly entered parking mode again and I have time lapse footage all afternoon whilst I worked around it.
I then took the car for a test drive where I can see the camera has successfully exited parking mode and I have real-time footage up until I came back home and powered the dash cam off so I could remove the memory card to review the footage I am discussing in this post.
As I believe I have identified proper constant and switched live circuits to tap into and the dash cam behaves correctly some of the time could someone provide further troubleshooting steps for me to perform as it would seem firmware related unless I am missing something.
PS - is there any on-screen icon that indicates whether the camera is in parking mode?
Many thanks
Hi All,
Many thanks
