Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A229 Pro TeleQuad (the best dashcam in the world!)
Yes - but it's just as likely to be condensation due to unit assembly in normal conditions as opposed to a dry purged environment. Seen this in other environments - other devices other types of equipment.^ Would condensation inside the lens mean that perhaps the lens body isn't well sealed/damaged ?
Would adding an extra glass in front of the lens be of any help? Someone helped me with my build by suggesting watch glass lenses (or the glass part of a watch).Yes - but it's just as likely to be condensation due to unit assembly in normal conditions as opposed to a dry purged environment. Seen this in other environments - other devices other types of equipment.
Motorcycles ridden in cool damp weather are major challenge - the wind chill can be extreme - often the coldest bits are glass (lens or lens cover) so any moisture sealed inside during assembly WILL condense on those surfaces.
Assembly in 100% dry nitrogen environments CAN help. It's common for rifle scopes and binoculars to be thus assembled for this very reason.
Another option could be a gore-tex breather patch - see this system used on vehicle lighting.
A shame if the C3 is fogging - makes it near unusable as an all weather M/C black box cam. My Roadhawk cams do not fog, The SJ1000 and Mobius (in waterproof cases) do.
Did you format the card in the camera by holding the camera and power buttons until the led flashes green?It's a 32gb that came with the camera. I'll check the make tomorrow and post it. It's 23:50 here and the wife doesn't understand that gadgets are far more important than sleep.
Ok. So I've reloaded the FWC3 firmware, I've checked the config file umpteen times, I know it's taken it as the date, time and video name has changed and it still refuses to auto start. It also ignores the auto power off time and switches off after about 10 seconds once power is removed. Setting as follows just in case i'm missing the obvious.
datetime=2014:10:21 21:49:30
datestamp=on
videostamp=FAZER 8
poweronrecord=on
autopoweroff=30s
moviesize=1080p
photosize=3m
videocliplength=3min
selftime=off
continueshot=1
videosound=on
wb=normal
recordingindicator=on
hz=50
motiondetect=off
ev=0
saturation=normal
gsensor=off
tvmode=ntsc
lapsetime=off
