barbagris
- Jul 16, 2014
- Spain
- Roadhawk Ride (x2) : SJ1000 : Mobius"B"
Simply? - I doubt it.Would adding an extra glass in front of the lens be of any help? Someone helped me with my build by suggesting watch glass lenses (or the glass part of a watch).
I'm thinking something along the lines of a pinlock shield like you'd find on a motorcycle helmet. Or anti fog coating/soap/toothpaste but it'd be annoying to always have to reapply it.
The moisture is INSIDE and will always migrate to the coldest bit INSIDE the casing. btw is the outer casing metal or plastic? (it will affect the thermal dynamics) - I've been through this and the only ways that work are:-
- Make sure the INSIDE of the glass is warmer than the rest.
- That there is ZERO moisture
- Ensure airflow inside the casing so condensation cannot form.
That or modify using a gore-tex (or similar) breather patch - so moisture warmed by the electronics is forced out of the casing. This requires making a hole in the outer casing. I'll try and take some photos of said patches later today.
Something for Rockthinking to be aware of methinks.
This problem is EXACTLY why I stopped using the SJ1000 as an M/C cam. In winter the inside of the outer lens fogged in 10mins tops. I tried thicker glass, laminated glass - to no avail. Improved it but not enough.
The DogCam RoadHawks do not fog even in REALLY severe weather. But they're only 720p so I really want the C3's to work so I can replace them. Right now it would seem they need a bit of R&D.
