Dimitris1976
I hardwired a A229 Pro with the HK4 kit and set it on Low Bitrate parking mode.
I powered the car off and it worked only once...
I had the cutoff voltage set at 12.2 volts (car is equipped with AGM battery) and it recorded flawlessly for 8 hours the first time.
After that it stopped working. When I turn off the engine and remove the key, I hear the camera announcing that is switching to parking mode, but I find only 1 set of videos (front, rear, cabin) recorded- the one when I am leaving the car - and nothing more.
When I turn the ignition on without starting the engine, the camera starts it's normal full resolution recording.
I did measure the battery with a multimeter and has a resting voltage of 12.8 volts (car off - camera running), so it's not that.
Do you guys have any idea why parking mode is not working?
