Today was the day where i turned the k2S dashcam to a side dashcam,,,, for which it is well suited thanks to the small camera units, and the remote head unit.
But i did run into some problems:
1 : The power cable for use with the OBD adapter are very short, though i have OBD port above throttle pedal and camera on lower part of B pillar in the same side, the cable can not reach
So for now i will have to use conventional power and miss out on the OBD stuff. ( not sure if i can lengthen the wire, at the USB A end it do look to be a regular USB plug, so will try that tomorrow )
2: The wire clamp don't work for me ATM, but is is due to me using a standard USB A to USB C wire to power the camera, it is only "physical" due to the larger plastic just behind the USB C plug, which i can trim if i want to.
But if i can get the original OBD power cable to work the issue also go away.
3: In my seat there is a airbag i think, so where i have the main unit placed now are not good, will have to move it, maybe to the center console.
First some footage from the new setup, after that a little video where i explain the install.
