Yikes! I just installed the little red anti-backflow diode board from amazon and nearly right away, I’m seeing temps of 112c, a 90c rise over ambient while recharging my LTO battery!! This is with a charge rate of 7.4A on a fully depleted battery. I wrapped the solder joints in some kapton high temp tape to prevent shorts inside the box, but left the diodes uncovered.
Strangely, after about 10-15 mins, the board temp is now down to 35c, or about 13c over ambient. This is much better! Not sure why it was so high at the onset and then declined, though. Current flow is still 7.4A. Break in period? High resistance on charging a dead battery? Not sure what is going on here. I stopped the charge after about an hour to let things cool down for another hour and then restarted the charge. Anti backflow board only hit 50c this time, then after some time dropped down to 30c or so.
Orange LED on the charger board is still illuminated…
Tomorrow, my new XT60 wire will arrive and I’ll finish the direct to battery hardwire install on my Volvo. Even the battery wire harness on the Volvo is complex, but I found a place for an easy add to a direct connect to the pos terminal that won’t interfere with battery changes or anything else. The negative terminal definitely has a current flow meter for the BMS, so the negative charge wire will go to chassis ground.
This temperature spike is hard to explain, maybe the thermometer reading was wrong? You could probably check it by touch, but 125°C is much higher than the boiling point of water and will burn your fingers.
I currently have 4 different anti-reverse "ideal diodes".
The same Red one rated at 15A, shown wired as tested, and the other 3 are shown from left to right on the bottom of image:
15A Grin, 20A Grin (small square) and 50A Black.
Here are the test results for the 15A Red Diode:
Ambient temperature 25°C
Test duration about 30 min, Constant Current, Voltage and Power were gradually growing as battery was charging.
When charging at 8A charging:
The Current drop negligible, about 0.01A
The voltage drop is about 0.14V
The power consumption is 0.14V x 8A = 1.12W
The Diode temperature gradually increased from 25°C ambient to 38°C and stabilized there
The Charger temperature (Inductor) stabilized at 56°C
When charging at 10A charging:
The Current drop negligible about 0.01A
The voltage drop is about 0.17V
The power consumption is 0.17V x 10A = 1.70W
The temperature gradually increased and stabilized at 45°C
The Charger temperature (Inductor) stabilized at 65°C
The Diode average efficiency is about 98.7%
There were no temperature, voltage or current spikes, nothing unexpected.
I tested including from a completely discharged battery at about 9V and at mid-point charge about 12V
I will test and post the results for the rest of the Diodes for comparison.
