50 or so times would be over a long period of time, maybe 3 years+. If you said 10 fixings / removals a day, then potentially (although unlikely as it wouldn't be every day), that's 50 times out of almost 22,000 removals / fittings. Not too high when you consider the juggling items with full hands scenario and the fact that quite a few were also mount failings. Yep I probably could go back twice to the car, but let's face it, most of us are lazy when it comes to things like that.
As for the case, I welcome the suggestion, but it would be an additional item to have to carry in the car.
Respectfully, removing and reinstalling a dash cam 22,000 times with no end in sight to the process sounds downright daft if you ask me but if that's your pleasure, I guess that is up to you.
In decades of working with and transporting cameras and lenses sometimes in precarious situations on location I've dropped a lens on a single occasion but that was about it. If I dropped
any item more than a few times I would consider that a problem exists that needs to be addressed. In your circumstances since you are not willing to use a tote bag or satchel to transport all the items you regularly need to, or even a small protective case to transport your camera to and fro I don't see much hope for your situation since it appears to be entirely self inflicted together with a refusal to adopt a simple remedy.
Do you really want to risk leaving a E / £ / $200 dashcam in a vehicle in areas with high vehicle crime? I've not heard of dashcam theft, but it's only a matter of time once thieves realise there's a market. After all throw out the SD card and the theft evidence disappears, plus if your vehicle is broken into, your insurance goes up to pay for the window / locks.
Well, if you leave a GoPro dangling from your windshield, well yes, I think thieves indeed may find such an item to be highly attractive but many of us opt for stealthy cameras such as the SG9665GC or similar wedge shaped cameras that look quite like factory installed OEM equipment and are not even quite so visible and noticeable from outside the car to begin with. Anyone living in such a high crime area would surely opt for something like this. The
Street Guardian SGZC12RC is another extremely stealthy option that one might consider for permanent installation in a high crime area. In my vehicle, my SG9665GC is mounted so that it just peeks out from behind the frit and is hard to see or notice at all. My Mobius cams are also stealthily installed and difficult to see from outside my vehicle. Even when detectable, I've learned that for the uninitiated they don't even register as cameras unless you know what you are looking at. Additionally, once installed properly a camera like the SG9665GC or Viofo A119 lend themselves to easy mounting and dismounting if that is your preference. With my Mobius cams I will sometimes just put the lens cap back on and stick it in a shirt pocket until I get back to my house if I decide to remove any of them from my vehicle. It is
that easy to avoid dropping them.
You wouldn't believe the number of times my GoPro mount has fallen off the screen. Hardly a poor quality mount.
Well, if you have a large high quality suction mount like the GoPro that is falling off your windshield it is likely not installed properly. These tend to remain in place securely, even on the outside of a moving vehicle until intentionally disengaged.
Silicone suction mounts tend to be magnets for dust and fine particles and overtime this can lead to a loss of suction or improper adhesion in the first place. The silicone cup should be swabbed with a damp rag and allowed to dry before installing. At the same time, it is vital to properly clean and prepare the windshield glass before installing the suction mount. Finally, one needs to apply appropriate pressure on the mount to remove as much air as possible
before engaging the vacuum lever on such mounts. Your results will be more successful if you follow these simple proceedures. For me, I have had suction mounts that have remained secure for many, many months at a time, although after long experience I've now come to prefer the benefits of an adhesive mount for permanence and stealth and use suction mounts only for temporary installations.
Maybe it's just me, but I don't see anything wrong with ruggidized cameras. Do we really want to pay £ / E / $200 for a cheap piece of brittle plastic or something made from quality materials and construction. I know what I want from spending that much money and if action cam companies like SJ can ruggidise cameras for well under a £/ E / $100, then I see no reason why dashcam manufacturers couldn't ruggidise cameras without any significant extra cost.
I'd say it is just you.
If you believe that manufacturers should produce dash cams intended to be dropped repeatedly onto the pavement because you are unwilling to put the thing into a small protective case I'm certain you will be waiting for a very, very long time indeed. Even action cameras are not made to such standards that they can be repeatedly dropped onto concrete, especially when they are not in one of those waterproof impact housings which in and of themselves have their limits. Action cams may seem rugged but they are by no means indestructible if repeatedly abused. And ruggedized external housings like those seen on most action cameras will never be seen on a dash cam, because of heat retention if nothing else and an exposed lens will be vulnerable to direct impact no matter how rugged the camera housing may seem.
