- May 1, 2013
- Dublin
- Ireland
Not exactly, 0803 also packs bunch of data to data stream inside of the mov file, so the single mov file contains video, audio and text streams. The text stream is compatible with subtitle stream, so video/movie player capable of reading subtitles can display the data as movie captions. The specialized player could read this data same way it reads it from separate file and use the data to track position on the map and display speed and other sensor data.
It is not really a redundancy. It just some formats could not carry text streams, so sensor data was logged separately. Mov files can be self-contained, so no need for separate files. It is probably the first step in the right direction.
Data example: V,0,0,,,,,,0,-00.61,-06.12,+02.45;
I have some other new dashcam based on A7 which also same way saves text data ( gps ) into mov video file and Registrator Viewer starting from 5.7 and up can decode gps data abd display correctly. All works fine. I guess 0803 has same principle.
