I've not been on this forum for ages (because I used to spend far too much time on it). The last time I was on here was in January, when I was waiting for the replacement for the 0801 to be launched.
Please pardon me because this has probably been covered before, but may I ask 2 questions:
- Is it pointless buying an 0803 right now due to firmware problems? If not, would someone please advise me which firmware I need (I intend to buy the 0803 with GPS but no internal 8Gb slot).
- Is there any major advantage in buying the version with the internal 8Gb memory slot? If there is, I can't see it - providing you don't take your micro SD card out and then forget to put it back in. I can't see the advantage between having an internal SD card and a spare SD card for the external slot. Maybe I am missing something here.
Thanks very much
I'm certainly confused.
What I've learned so far is that;
1. The 0803 is better than the 0801, particularly at night, and I like it.
(That said, I don't use the highest resolution, since I find 1080p is still sharper for number plates)
2. There seem to be multiple factories producing the 0803, with different components (like lenses)
3. There are multiple resellers, E-prance, Foxoffer, etc etc, and its not even clear if these are using single or multiple factory sources.
4. I have no way of knowing if the firmware is interchangeable between the different types, but reading recent accounts it seems that they might be factory (or even reseller) specific.
5. The firmware on mine is 20140507, and have no idea if upgrading would brick it or not.
6. My model is e-Prance with 8GB onboard + 32 external and GPS. I bought this model because Amazon UK could fulfill and if needed I can return it to them for support (I hope).
7. I can't see much use for the onboard memory. It was only of any use when I'd removed the SD card and forgotten to replace it. It automatically recorded on the internal memory instead.
finally,
8. For the price, its a bargain.
