Dukabmw
I think is the problem that I have just experienced and explained in the 0806 Freezing topicyes the two PWM ICs have the most damaged possibility. Sorry i don't remember why I just post a image but not leave any words
Quite possibly, it's a common issue with this modelI think is the problem that I have just experienced and explained in the 0806 Freezing topic
possible reason:
1st, card writing problem which crash the camera boot process; please take out storage card before power on and then format the card in camera.
2nd, ARM halt; hold power button for 16 seconds only reset DSP but not ARM, that is a design defects as ARM level usually will not halt but there is 0.1% possibility; disconnect battery will solve this. This will be changed in the following products.
3rd, PWM IC damaged as the input voltage is higher than 5.5V. This can only be done by hardware work.
Rayman.Chan,
I have the same problem with the DVR, but my DVR mini 0805.
help identify the item .
Power on 3V battery (with battery and without battery). IC temperature - processor about 40 degrees.
I replaced 4 pcs PWM ICs still the same.
thanksit is a RT8059GJ5
