Gurkha9
- Feb 4, 2013
- Montreal
- Canada
- GT300W, Mobius A, Mobius B
JayCam said:I may be being a bit stupid here. I've set mine up to auto record when the power is switched on, but I can't find a way to get it to stop when the engine is switched off (the cigarette socket is not powered unless the car is on). I assume it will just keep recording until the internal battery goes flat? Then it'll start up again when the car starts?
I've also noticed that it seems to feed power back into the car - if I plug it into the cigarette socket with the car off, my handsfree temporarily comes on - I assume it was hard wired into the cigarette socket by the installer! Is this usual, I've not seen it happen before? It leaves me a little concerned about leaving the Mobius plugged in once I've left the car, which means I can't really set it and forget it as planned.
If you have Auto Power Record on, then it should stop recording after you turn off ignition (within 15 seconds).
If it doesn't, you either have an 'always on' socket or something else is wrong perhaps with the installation.
