it appears that was the issue - Msetup wouldn't let me flash the fw with SD Card error. also, it didn't record at all yesterday .Most times mine has locked up, I have fixed it by reformatting the card.
File management with loop recording seems to be a potential issue long term. Regular reformatting appears to help. Not sure why this would be the case.it appears that was the issue - Msetup wouldn't let me flash the fw with SD Card error. also, it didn't record at all yesterday .
It allowed me to turn on wifi after formatting, everything looked fine . I guess that was the issue
never had these problems with the Mobius1
Could be a battery problem - not maintaining the Real Time Clock. Do you use a battery or capacitor? In recent testing with WiFi enabled my capacitor Maxi has been very reliable, however the battery Maxi had a few issues before the battery died.Unfortunately another couple of problems have surfaced.
First having used the WiFi to download a file the Maxi then just freezes up. Using the rest button works but hardly ideal.
Second, took the Maxi out of the car to change the time this morning and noticed that on the recorded files the time had messed up. The date was correct.
The photo's show the time on the file (which is the time the file ends) and then the actual time on the clip. Both are wrong as the actual time was around 11.00hrs!
Do you happen to know if Mobius are anywhere close to releasing a new fw with this bug fixed? this just happened to me again today. couldn't get the Maxi to record until I formatted the card using my phoneFile management with loop recording seems to be a potential issue long term. Regular reformatting appears to help. Not sure why this would be the case.
I can increase awareness of the issue with Mobius.
I don't think the Maxi is at a stage where it could be improved just with a hex editor, the improvements needed are still at a base code level, not quite there yet
I was only trying to be helpful.This repeated notion that "Mobius" is off somewhere in China, oblivious to all the problems, issues and concerns we all discuss here month after month is a myth. As has been made clear in various older posts by @Isoprop, the Mobius developer, a fluent speaker of English, has monitored this forum (along with RCGroups) for years as a so called "passive member" who never posts. Any unwillingness or inability to address any of the outstanding issues with the Maxi (or with the M1 or M2 for that matter) is certainly not for lack of awareness.
A small development team and a small group of volunteer testers can only achieve so much. I can't replicate the issues reported by some members here, so there's very little I can do to help, other than pass on a comment in the hope it will be looked at. I'd like to think that my involvement has improved the Maxi to some small degree, but perhaps someone else could and should do a better job of it? I'm sure I could have found more enjoyable ways to spend my not-so-spare time than testing 8 beta FW versions and 3 or 4 app updates over the last few months.from what @TonyM has mentioned previously they are still working on firmware, it just hasn't been released to anyone other than a few testers, perhaps that makes it look like nothing is happening, more testers could certainly speed things along for the Maxi, that doesn't seem to be their way of doing things though
Me neither!So it locked up on me again today. Took the SD card out and connected it to my Android phone -
noticed latest file recorded was 0 kb . Deleted it, and inserted the card back the Maxi, which was now working normally and recording. don't know what to think anymore
it's 2.8K, super fine, 3min loop .Me neither!
Please remind me of your settings (resolution, quality, loop duration).
Do you delete any individual files with either the app or PC/MAC?
