SYS cfg =
DateTime= 2018/04/01-12:19 ;date time setting,yyyy/mm/dd-hh:mm
DateTime_Update=0 ;confirm to update the Date/Time or not , 0: No, 1: Yes
DateStyle=0 ;set date format,0:YYYY/MM/DD, 1:MM/DD/YYYY , 2πD/MM/YYYY
Image_Size=0 ;set image size, 0: 2704x1524, 1: 2048x1536, 2:1600x1200,3:1920x1080,4:1280x960
Image_Quality=2 ;set image Quality, 0: Super Fine 1: Fine 2: Normal
Photπ΅sd=1 ;set photo preview OSD, 0:Off, 1:On
Time_Lapse=0 ;set TimeLapse interval, 0: Off, 1: 3sec, 2: 5sec, 3: 10 sec, 4: 30sec, 5: 1min
Time_Lapse_Duration=0 ;set Time Lapse Duration, 0: Unlimited, 1: 5Min, 2: 10Min, 3: 15Min, 4: 20Min, 5: 30Min, 6: 60Min
Driver_Mode=0 ;set shutter delay, 0: Off, 1: 2 Seconds, 2: 10 Seconds, 3: 10 Seconds double exposure
Photo_Burst=0 ;set Photo Burst, 0:Off , 1: 3 photos, 2: 5 photos, 3: 10 photos
Video_Size1=3 ;set Video1 Size,0:3840x2160(24fps),1:2704x1524(30fps),2:1920x1440(30fps),3:FHD(60fps),4:FHD(50fps),5:FHD(48fps),6:FHD(30fps),7:FHD(25fps),8:FHD(24fps),9:HD(120fps),10:HD(100fps), 11:HD(60fps),12:HD(50fps),13:848x480(240fps)
Video_Size2=9 ;set Video2 Size,0:3840x2160(24fps),1:2704x1524(30fps),2:1920x1440(30fps),3:FHD(60fps),4:FHD(50fps),5:FHD(48fps),6:FHD(30fps),7:FHD(25fps),8:FHD(24fps),9:HD(120fps),10:HD(100fps), 11:HD(60fps),12:HD(50fps),13:848x480(240fps)
FOV=0 ;set Field of view, 0:Wide FOV, 1:Narrow FOV
Video_Quality=1 ;set VideoQuality, 0:Super Fine, 1:Fine, 2:Normal, 3:Extreme(Warning: may have some dropped frames for some memory cards or other issues if set to Extremely High Bitrate.)
Media_Format=1 ;set Media Format, 0: MOV, 1: MP4
Sharpness=2 ;set Sharpness, 0:Super Hard, 1:Hard, 2:Normal, 3:Soft, 4:Super Soft
Saturation=6 ;set Saturation bias, 0:-6, 1:-5, 2:-4, 3:-3, 4:-2, 5:-1, 6:0, 7:1, 8:2, 9:3, 10:4, 11:5, 12:6
AE_Metering=1 ;set AEMetering method, 0: Center area, 1: Multi spot, 2: Center spot, 3: Top, 4: Bottom
Exposure=6 ;set Exposure bias, 0:-2, 1:-1.66, 2:-1.33, 3:-1.0, 4:-0.66, 5:-0.33, 6:0, 7:0.33, 8:0.66, 9:1.0, 10:1.33, 11:1.66, 12:2.0
Movie_Voice=2 ;set recording voice, 0: Off, 1: Low, 2: Normal, 3: High
Ext_Mic=0 ;set extern micphone, 0: Off, 1: On
Stabilizer=0 ;set stabilizer, 0: off, 1: on
Loop_Record=0 ;set loop record, 0: Off, 1: On
Recording_LED=1 ;set recording LED, 0: Off, 1: On
Clip_Length=1 ;set clip length, 0: 1 Min, 1: 3 Min, 2: 5 Min, 3: 10 Min, 4:15 Min, 5: Max to 4G
Invert_Mode=0 ;set sensor Flip, 0: Off, 1: On
Auto_Flip=0 ;set auto flip on/off, 0: Off, 1: On
G_Sensor=0 ;set gsensor sensitivity, 0: Off, 1: Low, 2: Medium, 3: High
White_Balance=0 ;set white balance mode, 0: AWB, 1: Daylight, 2: Cloudy, 3: Tungsten, 4:Fluor
AE/AWB_Lock=0 ;set AE/AWB lock(quick press power button to set locks), 0: AE/AWB lock off, 1: Both AE/AWB, 2: Only AE, 3: Only AWB
Videπ΅sd=1 ;set video preview OSD, 0: Off, 1: On
Motion_Detect=0 ;set Motion Detect, 0: Off, 1: On
MD_Sensitivity=0 ;set Motion Detect Sensitivity, 0:High, 1:Normal, 2:Low
MD_Timeout=2 ;set Motion Detect Record time, 0:5s, 1:15s, 2:30s, 3:60s, 4:3Minutes, 5:5Minutes
pwn_auto_rec=0 ;set Auto Record with external power, 0: Off, 1: On
TV_Full_Screen=0 ;set Full Screen On/Off, 0: Off, 1: On
