Necromancer
- Sep 30, 2013
- Israel
Your mobius holds time & date correctly with the supercap in use only few times a week? mine never has even when i used it 5 days a week.
The time has drifted by a couple of minutes since last updated in mSetup. The date is correct.Your mobius holds time & date correctly with the supercap in use only few times a week? mine never has even when i used it 5 days a week.
I left my car on the driveway for 6 days. Auto-record on the M1S worked OK the next time I started the car, but the capacitor did not maintain the clock for that duration.My new Mobius 1S has a capacitor and I'm evaluating pre-release FW V1.21 with power-off disconnect set to 5 seconds. (Other delay options are being considered. I have already proven that 10s is too long).
The M1S records for 5 seconds after the engine is switched off, has enough charge to maintain the clock, and auto-records every time the car starts. I use the car at least 5 days a week.
That's not a small issue. The camera should save the last file before shutting down, even on the 'immediate' setting. It sounds like your capacitor is dead.I recently went back to the supercap for my Mobius after in the last years I used only batteries and I probably forgot about this "small issue" (don't remember tbh if this was the case in the past also)
Obviously, the setting is to shutdown the camera immediately when the engine is turned off, but from what I saw, the last video is always missing from the sd card...so it's not saved.
Is this normal? Or is the supercap dead?
E | Looking for original Mobius1 | Mobius | 1 | |
T | How big of a file can be saved on Mobius with super capacitor on loop immediate power off? | Mobius | 23 | |
P | Mobius Super Capacitors SUPER HOT | Mobius | 5 | |
Super easy DIY CPL (GLASS!) filter for Mobius wide angle lens | Mobius | 13 | |
Can the Mobius Super Cap be used in the 808 #16? | Mobius | 4 |
