TonyM
- Jul 30, 2013
- United Kingdom
- Many dashcams over many years
That must be a mistake in their website. There's nothing in the hardware or firmware that supports image stabilisation.Seller eletoponline365 on eBay claims image stabilization feature. Too bad if there is no stabilization as it really limits use as an action cam. Not very good when biking in forest or uneven surfaces.
I had that happen once during testing. I took it apart, cleaned the inside of the lens and it didn't happen again. It's only waterproof if you screw the bung into the microphone socket and also put the blanking plate over the rear face. I suspect moisture can build up inside which then condenses on cold days. It is Mobius' first attempt at a waterproof camera and it's not as robust as something like a gopro.One thing I noticed is that the lens gets really foggy when going outside from normal room temperatures. This happens really often after 15-20 minutes. It is so bad that you cannot see practically anything. When going back inside it goes away after 5-10 minutes. It feels strange if this really is supposed to be waterproof.
