Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
I believe the problem is to do with adhesive outgassing, had never really given a lot of thought about where it was originating from but given where it occurs and the fact that it can be cleaned off I guess it is quite possible it's the adhesive used on the IR filter that was the culprit, if it was from something used on the internal lens elements then the fog would end up trapped inside, only other possibility to cause a problem in that space would be from the CMOS sensor but don't know if there's anything used in the manufacturer of a sensor which could cause this, not even sure what hardware they used on these
The IR filter adhesive outgassing fumes sounds like a good possibility. Or perhaps the glue they used to set the lens? Either way this is a good example of the kind of thing I've been talking about here and in this case at least it is still cleanable which with some contaminants might not be.
