Usually Unfocused
I don't think there is a way to auto start the camera into picture mode. It has to be done manually after startup.
Ouch. I'd not grasped that despite all my reading.
That rather destroys my whole project......
The rear LED indicates if the camera is recording or not. It will blink when recording, otherwise it will be on when the camera is in standby, except, maybe, at startup, before any buttons are pressed.Separately, I'm confused about the rear LED. It's not mentioned or seen in the Aug version of the manual.
I gather it's supposed to be on when recording, but I get into a mode where it is on, but the top LED is dark.
What does that mean?
I have never seen the rear LED on when the other LEDs are off. This is not possible, IMO.
You have it connected to your PC, so the Mobius is connecting as an external disk drive.How do I set it up so I can get into time-lapse mode while powered?
- I have it plugged into the USB for power.
- Auto Record is 0
- It's powering up in Yellow mode.
- I need to get it into Red [time-lapse] mode. [Since I can't make that the power-up default, I now know...]
- So I hit the mode button; no change, still yellow. Huh?
You must use external power that doesn't use any handshaking, i.e. pins 2 and 3 must not be connected. All you need is a +5V and a ground.
The best is to download mSetup and using it to download and install firmware.
There is a new version of firmware. The best is to download mSetup and using it to download and install firmware.
You can see the new options in the mSetup GUI.
enjoy,
Mtz
Usually Unfocused said:Should I really fear the direct approach of loading the firmware to flash, and executing the upgrade from there? What does chasing down a Windoze machine to use buy me for this task?
I used to use the Text only method on my Mac, but once you use mSetup on a PC there's no going back really.
Too many possible pitfalls using the geeky way but it can be done if so inclined. But nah, I just bring it to the office and use the Windows 7 machine there.
Niko - if you downloaded mSetup from the proper place there is no problem with the software, although I have yet to install the latest version released this week.
Then I would think that it's safe to proceed as that is the right site
I don't know what anti virus program you are using, but it's showing you a false positive.Strange,
I downloaded mSetup, but antivirus scanner giving me a warning message "mallicious".
Any comment on that ?
