The new screen shots look somewhat grainy but on the whole not all that bad and certainly much better than the first images you posted from the other lens module. The Mobius does pretty well at night all things considered, but its never been spectacular.
Did you watched them in full size? Because in a smaller size they actually don't look that bad. It's only in full size that the coloured graininess is more noticeable.
I made a video with the test clips I recorded yesterday and uploaded it to YT. If you watch the video in 720p it smooths the grains and the quality is acceptable but if you watch it in 1080p, even in a small screen, it's pretty bad, just like in the raw files.
Some graininess is normal as long as you can capture what is going on and the new images seem essentially to do that. With my Mobius cameras, especially because I live in a rural area where often I drive down roads with no street lights sometimes it does look grainy (and sometimes not) but I'm fairly pleased with the results. The Mobius performs so much better than early dash cams that I owned years ago that were basically useless at night, so I'm OK for now with the performance and hope for better as new technology becomes available. The Mobius is already getting pretty long in the tooth.
To be honest, I don't see any differences between the first camera and this one. The new screenshots may perhaps look a bit better because the conditions were different: no rain, less reflections and the lighting of the place where I did this last test is a bit better too. I also tried to record as much as possible the added illumination from the car's headlights to see how the camera reacted to a better lit environment.
I only have the G1W-H and the AT11DA's night quality to compare the Mobius with and so far both of them beat the Mobius hands down. If this is really the best the Mobius can do then I must say I'm a little disappointed because I was expecting something better than what two no-brand generic cameras can provide.
But I'm still not convinced. From what I've seen and from what people say, it has to do better than this.
If you really need better night time performance you might need to go with a camera that has a Sony sensor or wait to see how the Mobius 2 performs. You might also try experimenting with other menu settings on the Mobius just to see if anything improves.
I don't need excellent night video quality (but I wouldn't mind having a camera with a Sony sensor
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
), I'd be happy with something similar to the G1W-H's quality. The AT11DA is a bit darker and doesn't capture as much detail at night as the G1W-H, but doesn't have the graininess this Mobius have.
If I could I'd make one out of the two: the G1W-H's night quality and 15Mbps firmware with the AT11DA's lens, which is better and has the FOV I like.
I haven't played with the Advanced Image Settings yet (well, except for the test with
@petepete's settings) but I will, just for the sake of it, because I find it wouldn't have to be neccessary to resort to them to get the camera to work properly at night. And then there's always the question if those settings won't mess up the daytime quality.
