jimn
- Jul 12, 2015
- United Kingdom
In the 2.3 firmware the only choices are 12 & 24 hours.I take it you have not use the new setting and set the new Parking mode timer to 30 mins?
If you click on choice 30mins and 1 Hr become availableIn the 2.3 firmware the only choices are 12 & 24 hours.
Never used/saw that option and the time until recording stops is random.I take it you have not use the new setting and set the new Parking mode timer to 30 mins?
Seems like a good thing to me. You only want it on when you need it. Turning it on decreases video quality significantly.Another problem with v2.3, when the device is given Acc power and starts up, wi-fi is turned off (it was definitely enabled when it previously shut down) and after manually starting it the password had been reset to the default.
How much longer do we need to wait for V2.xx firmware to be released? Getting ridiculous that the firmware update is taking longer than the life cycle of the camera!
I'm not sure I believe that and I don't want to be farting around with the device before I connect the app and view/download videos.Seems like a good thing to me. You only want it on when you need it. Turning it on decreases video quality significantly.
Well documented elsewhere in this forum leaving wifi on all the time is a bad idea. I think you just press and hold the middle button to turn wifi on.I'm not sure I believe that and I don't want to be farting around with the device before I connect the app and view/download videos.
Right hand button, and yes, there is a substantial drop in bitrate while it is on. Also generates extra heat which is unwanted.Well documented elsewhere in this forum leaving wifi on all the time is a bad idea. I think you just press and hold the middle button to turn wifi on.
Yes.Once off does it stay off?
while waiting for U1000 to arrive I tested V2.3 firmware and found it less responsive than v1.9. Pausing recording takes longer and also to get to main menu. I had emergency recording go off when i started driving had to restart camera. also had constant beeping when car was in park mode and didnt stop beeping. decided to roll back to v1.9 for time being.
[/QUOT
+1while waiting for U1000 to arrive I tested V2.3 firmware and found it less responsive than v1.9. Pausing recording takes longer and also to get to main menu. I had emergency recording go off when i started driving had to restart camera. also had constant beeping when car was in park mode and didnt stop beeping. decided to roll back to v1.9 for time being.
What are your settings, because it doesn't appear to be working for me?It seems the parking mode is fixed. Left it running on my desk and minor movements make it lock the recording.
Shouldn’t need previous boot loader to install older firmware.I need to go back to v 1.9. any link to the correct boot loader?
