The GUI seeming to go back to less options for when me added 0.59 back to Mobius.Do you know where can i find older versions of mSetup, the GUI configuration tool?
The latest GUI should be compatible with ALL Mobius FW versions that ever existed. In addition, bugs that were found in previous versions will have been corrected. Some tooltips my not be correct, since they apply to the latest FW versionsThe GUI seeming to go back to less options for when me added 0.59 back to Mobius.
So it was liking when I had older GUI version. But some say it forget setting in new GUI, maybe here or RC forum. Hope not.
I love the time lapse features in v2.10 and not sure I could live without that but I'm going to go all the way back to 0.47 and work my way up to see what you're all on about!
Yes, that will work, but remember the Mobius will require an extra ~30 seconds to start. I would avoid using this method if you use auto-power-onI think (not sure) that you can have, say, v2.10 on one micro sd card & v0.53 on another, & swap cards on the fly when recording video clips. May help speed up the firmware comparison process?
It would involve copying the firmware .bin file to the card, then use part of Method 2 of the Manual Firmware Update process described in the User Manual (from 'turn on the camera & wait', etc). You also keep your settings in a read only config file in the root directory of the card (make it a 'read only' file by changing the file attributes with your PC).
So, you swap cards, then do a manual firmware update, followed by a manual config upload.
I'm sure @Isoprop will say if the above is incorrect.
Are you also to trying 0.59FW? It has not failed me to start and also very nice pictures. I drove it at the night and was impressed very.The latest GUI work absolutely fine on firmware 0.47 for me like isoprop said it would.
Couple of clips for those that want to see footage from 0.47 version using a B lens:
I ran this side by side with the latest super cheap camera and this slaughters it at night![]()
Thank for posting your information. Unfortunately, I could not replicate your findings. Without having your syscfg.txt file or original mSetup.cfg file it's all but impossible. Everything worked fine on my tests using default values. However, I can well imagine that one or two parameters from your profile are not imported correctly because they no longer exist or are different in the latest firmware. When you upgrade/downgrade the firmware to a release with less/more parameters there is a warning message that tells you some parameters have been set to their default values. With some combinations it's impossible to evaluate the corresponding new value. All the same, that's not an excuse that there is an empty radio button or two buttons change together. If I could replicate your scenario I would correct it!@Isoprop, i think i found the issue with mSetup radio buttons start to act weird. I'm sorry, but for now i don't have time to upload the SYSCFG. this is the scenario:
1. Using FW1.13 and the corresponding mSetup GUI (2.0.3.5?) save a template of the camera settings
2. Upgrade to FW2.10, upgrade also mSetup GUI to latest version
3. From mSetup load the template saved before and save it to camera
4. Go to mSetup "Video mode settings" and change from 30 FPS to 60 FPS
look at the FPS radio buttons, when you change Mode1 FPS value, Mode2 FPS value changes also. also after setting the correct FPS value you want and reconnecting the camera, FPS values are not saved.
hope this scenario is detailed enough so you can recreate it.
so, for now, ill stick with FW1.20 low light enabled.
