Hello friend, no answer to fix anomalies of 'MINI 0807?
Jeremy Wang replied above. (The changelog says: Fix the bug of Pre-record mode (parking guard function); raise the bit rate.)
Jeremy Wang did not respond to me, that I have to disable that function to operate the GPS?Jeremy Wang replied above. (The changelog says: Fix the bug of Pre-record mode (parking guard function); raise the bit rate.)
Can I know which features that you've disabled? Maybe I can test on my 0807 and see if it is the same issue or not...
... Never mind ... you can place these BUGS? I have to travel for many days and I would have MINI0807 working, I bought this model because it seemed the best ... thanks@NAVMAN if you read properly, I asked the above which you didn't reply. And you say I didn't answer you?
I seem to be having some corrupt files with my mini0807.
I am using 2 X Samsung 128gb EVO plus micro SD cards 90mb/s.
Maybe these cards are too fast?
Can somebody help please?
Thanks in advance for your replies.
I'm using two 64GB Lexar 633x, haven't had a corruption issue yet.
Are you using the latest firmware?
Some window tints actually blocks GPS signals.
I don't have an issue with my 0807's GPS getting connected.
Jeremy,
I have a similar problem with the GPS locking on to the signal. Let me provide a little more insight as to what I am experiencing.
Here are my symptoms:
I hope this makes sense to someone with the power to look into the programming code. Perhaps there is a simple issue with how the GPS routine attempts to lock onto the satellite signals.
- I have to disconnect and reconnect power at the 16-pin OBDII port in order for GPS to lock on when there are no obstructions above my vehicle.
- The issue begins when I start my vehicle inside my garage. I find that the GPS won't connect on its own for quite some time afterwards even when there are no more obstructions (perhaps over 15 minutes while driving 'in the clear'). But, like NAVMAN said, all that is needed is to quickly disconnect and reconnect power and the GPS will lock on almost immediately. It puzzles me why the GPS wasn't able to lock on during the previous 15 minutes? It is like as if it gives up until I power cycle it.
- Once the GPS has locked on, then subsequent vehicle starts work correctly while the car is 'in the clear' . But, it is just when I start the vehicle under an obstruction that I notice it giving up early and never locking on to the satellites, or at least never in a reasonable amount of time.
Thank you,
Joe
I am unable to get my 128GB cards to work - the first .mov file recorded will usually play and the rest cannot be played either with QT or Dashcam Viewer. As the manual says, these need to be formatted to FAT32 off the camera. I have absolutely no problems with 32GB cards and it may be the quality of the 128 ones that are the issue since I bought cheap ones. So if anyone does know what 128GB cards work well, I`d also be interested. So far however I am impressed with the cam.I am now testing the Samsung 64 gb EVO and it is working fantastic without any errors.
It's with the Samsung 128gb Pro plus micro SD cards which I am having problems with, these are fast cards and it seems that the mini0807 is not happy handling these cards.
Could anybody out there suggest any 2 X 128 gb micro SD cards which are working well in the mini0807?
I am using the latest firmware, Thanks......
The seller has been removed from eBay so that probably tells it's own story! The cards were unbranded.What card do you have, got a link to what you bought?
Yes I guess I really know that deep down - still before I shell out real cash it would be good to hear of cards this size that do work without issues.If you paid less than around USD $50 save the heartache and just get another card, unbranded 128gb cards are not a good sign either really, 99% odds you have an 8gb card at best
I too had problems with 128gb sd cards and I was using top quality Samsung sd cards. I would suggest to use 64 gb cards as since then it is working flawlessly. The 2 x 64gb cards still have sufficient memory so that is what I would recommend unless you are going for a long holiday and would like to record your trip.Yes I guess I really know that deep down - still before I shell out real cash it would be good to hear of cards this size that do work without issues.
Good advice ~ I'll go with that.I too had problems with 128gb sd cards and I was using top quality Samsung sd cards. I would suggest to use 64 gb cards as since then it is working flawlessly. The 2 x 64gb cards still have sufficient memory so that is what I would recommend unless you are going for a long holiday and would like to record your trip.
Hi Navman, here is the newest firmaware of Mini0807: http://www.skyhigh-global.com/En/down.aspx?UserInfo_ID=862928 ( 807 bit rate 20160623), pls follow the steps tips to upgrade the firmwares (latest DVR/MCU/GPS).
hope can help you.
"We will add a function on Mini0807 parking guard: over temperature protection.
if the temperature is extremely too high, the camera will be turned off automatically to protect the camera."
This feature was added to the new firmware, ?
@BELLA WONG @jokiin
