Did anyone succeed with A129-G Plus Duo connected to power bank (not HK3 and not HK2) using USB cable shipped with camera and parking mode setup?
I've read in manual that using Viofo Hardwire Kit (HK2), which is power supply adapter only with two wires (+12V and ground), which power up camera all the time no matter what ignition state is, can be also set up for parking mode, because camera should switch to parking mode after 5 minutes of no motion detected and no G-sensor shake/motion readings.
I suppose that power bank is HK2 equivalent. I set "parking mode" to "Low Bitrate Recording", "Enter parking mode timer" to OFF, "Parking recording duration" to ON, "Parking G-sensor" to "Middle Sensitivity", "Parking Motion Detection" to Medium.
When device is booted up it shows parking mode in drive mode (car with small camera).
I turned off screensaver in settings to see if camera will switch to parking mode after 5 minutes. And yes, it does. After 5 minutes of no move screen goes to OFF, even if I configured screen saver to OFF. Then after pressing any button I can check that in fact it switched to parking mode (camera icon with small P instead off car icon).
Great. Screen goes off after 30 seconds in parking mode after button click.
But working in parking mode it never switches back to drive mode whatever I do. Manual says that it should switch to drive mode when G-sensor will receive shake/motion. Well in my tests it never switches to drive mode. When i shake it nothing happens. When I shake it harder it locks recording (parking incident detection). But it never switches to drive mode.
Anybody know what is the condition switching from parking mode back to drive mode without Viofo Hardwire Kit (HK3)?
Maybe Viofo Hardwire Kit (HK2) uses additional cable pin which makes it different than regular cable connected to power bank?
Or maybe my parking mode configuration I described above is faulty?
My firmware is updated to latest available:
A129Plus: V1.8
Build2: 20220706
Rear: V1.7_20210416
A129Plus: V1.8
Build2: 20220706
Rear: V1.7_20210416
