I had so many problems with those versions that I went back to the Aug. firmware version. I'm curious, did the bug cause the screen to display "Memory Error"? If so, that's a very misleading message that might make people think that their memory card is bad. Since I went back to the Aug. version, I haven't had any "memory" errors even though I'm still using the same card.There is some bug for A119 V2.0 and V2.01 firmware, it cause the dashcam view can not read the GPS data.
We have fixed this and released V2.02 version.
http://support.viofo.com/solution/articles/19000019600-viofo-a119-car-dash-camera-firmware
What kind of memory card do you use, I suggest you format the card again in the camera, or use the GUIFORMAT tool.I had so many problems with those versions that I went back to the Aug. firmware version. I'm curious, did the bug cause the screen to display "Memory Error"? If so, that's a very misleading message that might make people think that their memory card is bad. Since I went back to the Aug. version, I haven't had any "memory" errors even though I'm still using the same card.
I have a class 10 memory card and used the recommended format tool. Formatting in the camera does not seem to work because it finishes too quickly to have done a format (less than a second). One time, it lasted a few seconds but it didn't seem to completely format the card. I have followed the instructions for installing each of the firmware versions even though some of the steps for the newer ones seem odd.What kind of memory card do you use, I suggest you format the card again in the camera, or use the GUIFORMAT tool.
I would still like to know the answer to this question. How did your reported bug fail?I'm curious, did the bug cause the screen to display "Memory Error"?
As I wrote, I have done that. It's been working without problems for several weeks now. I'm not touching it again unless I have to.Normally while there is a memory error, most of the time it means the card is not formatted in FAT32 format.
We suggest you try to format the card using GUIFORMAT, and then use card test tool to check the card status first.
That DashWare app looks pretty cool!
