I'll keep thinking, but shouldn't the GPS already be powered up from being in Parking Mode? It sounds like you have your X2 completely shut down while away.
As per my original post, this only happens from cold boot (shutdown)... not parking mode.
Do you have any other GPS dashcam devices to see how fast they lock as a test? (or did you have anything before the X2) This will help judge and rule out if you have another interference going on. When testing make sure the X2 is powered off so the CMOS doesn't cause interference and skew the results.
So, after 5min cold boot you turn off car engine ( X2 goes into parking mode ), then after few minutes you start a car engine and gps lock immediately, right ?
I use to have a Cammsys CL-100B prior to this and it locked onto GPS well within 1 minute...
Thats correct... Problem only from cold boot... from Parking mode GPS locks on almost instantly.
Both devices are brand new... only had them a few weeks and has been behaving this way since day 1.
I could test one of my GPS units, and measure the time. If it's good I'll ship to you and see how that goes.
Sounds good.. let me know how it goes.
should be close to a second in this situation- From losing GPS signal if going thru a tunnel, recovery is about 15 seconds when coming out the other end of tunnel.
no probs..
have done more testing myself:
- From cold boot and not driving ( staying stationary) GPS never locks on
- From cold boot and start driving , GPS locks on after about 5 - 6 minutes
- From parking mode GPS locks on instantly
cheers
no probs..
cheers
