- Nov 25, 2013
- Shenzhen
- China
- B1W/B2W/B2K/B4K/DV688/DV988/B1M/B2M
PM you already!Can you please post the link for your official hardwire kit?
I have seen other posts here have mentioned that the g-sensor setting in the menu does not affect coming out of parking mode, so it doesn't matter if you have it on high. it is hard-coded into the firmware. That menu setting only affects when it makes locked recordings while it is already recording.
Any type of movement has the potential to trigger it coming out of parking mode.
okHi, would I be able to get the beta firmware for auto parking with wifi off? Thank you!
I have to say, I just tried it with a low and high setting. I had to bump the car pretty hard to start recording in parking mode with low sensitivity, and it only took a small bump to start recording with high sensitivity, so it would seem (to me, at least) that the sensitivity setting affects parking mode as well. Should I have waited 3+ minutes before bumping it? I guess I'll try that tomorrow.
The G-sensor setting in the menu will affect the parking mode trigger, and suggest that you set its G-sensor level to be Middle!@estore009 Is there an official answer available for this? Specifically, does the g-sensor setting in the menu affect the 0614s parking mode trigger? Or is the 0614s parking mode trigger hard-coded into the firmware? Thank you!!!
PM you already, please check!Hello, I would also like to get a beta version of the firmware with a auto parking mode, can you provide me with it?
PM you 0614s firmware already, please check!I'm getting ready to install the B1W in my car. Can I get a copy of the latest beta firmware?
PM you 0614s firmware already, please check!Could I get a copy of the latest beta? Thanks!
Hello. Can I get the firmware version with automatic parking mode? Thank you.If you like, you can try the newest beta auto parking firmware which based on Time+ G-sensor!
Just wanted to make sure this is the normal behavior for the B1W auto-park firmware:
I park and let the car sit.
After about 3 minutes, it announces that recording has stopped
LED goes from blinking to steady
LED light stays on steady
Does this mean if it's in park mode, the LED just stays on steady and it'll just keep monitoring until the G-shock sensor goes off? And then it'll start recording?
