Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
iPhone captures turbo-prop. (In tricky lighting 🙂)
(When will dash cams be able to do this? 😉)
So is it a photo or screen grab of a video
Is there any exicf or what ever it is called info on it ?
For a photo i would say its near a miracle shot, for a video frame i could better understand it.
If it really is a photo some one need to get that fruit-phone camera sensor in a dashcam ASAP.
Could be coincidence. As the image is scanned in one line at a time, the prop might be rotating enough that another blade (or even the same one) is in the exact same position.
Sent from my SM-G903F using Tapatalk
Not very likely.
Unless of course someone cherry picks a photo. It's easy to present an abnormal event as if it were evidence of something.
You already know these things. But you have to argue, don't you.You were speculating about "coincidence" which has nothing to do with how cameras function. And how is a camera's freezing a spinning propeller blade an "abnormal event"?
The coincidence would be the timing of the blade rotation matching the timing of the rolling shutter effect perfectly. (Not the shutter time, but that time divided by the number of scanned lines.)
That is the abnormal event too.
You yourself thought it was exceptional, that's why you posted the image.
Speaking of how cameras work, you seem to have forgotten that film cameras can show similar behaviour when using shutter speeds faster than the shutter can actually handle (second curtain chases the first curtain to form a slot that scans down the film area.)
if engine RPM is a multiple of that then it's going to look still, same reason car wheels can look like they're not turning when recorded driving along the highway when they hit a certain speedThe coincidence would be the timing of the blade rotation matching the timing of the rolling shutter effect perfectly. (Not the shutter time, but that time divided by the number of scanned lines.)
Whatever the reason for the iPhone's freezing the propeller blade, especially without any rolling shutter distortion it is still impressive.
more good luck than good planning, ask them to do it again and I'd bet they'd struggle
I've not seen a dash cam that would have captured that image.
