Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
I would probably have a SG9665GC if it wasn't for the big sensor housing on my windscreen which blocks the line of sight to one side unless a cam can sit underneath (which in my case would not be easy to comply with UK laws regarding objects obstructing the driver's field of view).
I have a similar situation due to a required vehicle safety inspection sticker directly behind the rear view mirror in the dash cam "sweet spot". I have my SG9665GC mounted about 7 inches to the right of the rear-view mirror mount but aimed towards the center of the road. Simply attach the SG mounting plate with an extra layer of 3M VHB tape in a vertical strip along one side so that it points the camera a few degrees to left or right depending on your vehicle's requirements. The mini 0806 is supplied with some small mounting wedges just for this purpose but you can achieve the same thing with a bit of extra VHB tape. If necessary you can even use two extra layers of tape along one side to tilt the horizontal axis of the camera a few extra degrees. This method will not affect the adhesion security of the mount even if you do not have full contact along the entire back of the mounting plate.
