It is pretty easy to fix, and you only need to remove 4 screws and the cover.
It is easy to make the sd card stay in place after removing CAREFULLY the glue on sd slot.
Just push the card in place, and press on the L shaped metal piece, then release pressure, the card will stay inside.
I've posted in the other thread of about SD card not locking in.
Well, I somehow got the SD card to stay in for a bit(it popped out 3-4 times in a row while I kept moving the L latch to get it to lock in the card). I put black electrical tape over the slot in case it flies out of the dashcam while I'm driving.
I put it side by side with my G1W-C and have to say, the picture quality is crap for what novatek nt96650 is known for.
Here are a screenshot of the same moment on both dashcam.
G1W-C:
A118C:
After driving for 30 mins(45 mins to get to work).
I started to hear the A118C start up sound and realized, it began rebooting.
So I got curious and switched the power cable between G1W-C and A118C.
A118C was then recording fine again while G1W-C didn't start up anymore.
I regret quite a bit getting this A118C after G1W-C has been stable for such a long time.
What won me over was the form factor and seeing that it's one of the newer capacitor dashcam.
However, I can't say it's build as good or as reliable as the G1W-C at this point.
I've spent more time fixing this A118C than actually using it so far.
List of issues:
1. SD card got stuck due to glue on speaker
2. SD card won't lock in anymore after glue is peeled off
3. Power adapter seems unstable at times
4. Don't know when the SD card will fly out(hopefully not at my eye again).
5. Video quality seems subpar vs other dashcam that uses same chipsets
Will never buy a new dashcam on the market until it's at least 6 months to 1 year old. I would've thought all the problems are ironed out with the original A118 version.
Dear all,
Thank you for very much for your orders and also for kindly bringing the issues to our attention. We wish to apologize for the difficulties you have been experiencing regarding the functionality of your device. We've never expected all those issues, as well as regard your guys as our tester. It's our fault being not able to find out problems, as we've cooperate with the manufacture for a while and have been cooperated smoothly. For the SD card slot issue, they are some kind guys already shared how they fixed that, maybe you can also fix your according to their post if your camera has that problem. As for the focus and video quality problems, you may try setting it a little bit, like turn off the HDR. For other functioning problems, you may try to update the firmware.
Also I would like to apologize for the later reply. It's better to contact me directly by PM me or sunny@gearbest.com if you need any help, as I am really too busy to check all the post recently.
Thank you for your kind support and patience.
Best,
Sunny
Now I'm nervous as hell and kicking myself for not going with the Street Guardian. I couldn't justify the $100 difference in price at this time, so I went ahead and bought the A118-C from @GearBest on 12 March. It seems like @jokiin & @Pier28 would handle any issues like these in a MUCH better way. Guess I'll keep my fingers crossed that I will get one that doesn't have the SD slot issue, the power cable issue, the focus issue and/or the overheating issue! Live and learn and buy Street Guardian next time.
