Hmm I can't say the night video looks any better than my old Mini 0801.Here's a sample video at night time (default settings, so wdr is on), about 10 minute in since the device started.
This is using the A118C_FW_0320 firmware posted earlier by @billknow (though the FW version on device says 3-12)..
I think this night video looks "good" (slightly better than before; less glaring of street lights) for this class of chipset/sensor/lens. Keep in mind that at the beginning of this video, you were mostly in a wide open area with very few buildings or background to reflect light. Towards the end of the video, you approach an intersection with slightly more objects to reflect light and the video looks a bit brighter.Here's a sample video at night time (default settings, so wdr is on), about 10 minute in since the device started.
This is using the A118C_FW_0320 firmware posted earlier by @billknow (though the FW version on device says 3-12)...
https://www.dropbox.com/s/1pd420b4lyedifd/2015_0401_213923_155.MOV?dl=0
Test your SD card with something like h2testw.Update...I ordered my A118c on 12 March, it shipped on 16 March, and I received it on 06 April. Checked it immediately for the SD card issue and found mine works just fine; the card clicks in and out just like it should. I hardwired mine, so I can't comment on the power supply issue. I'm also very pleased with the focus, but I haven't driven for an extended period of time to see if the focus/heating issue exists.
However, I noticed something that might be a problem. The first few files saved just fine, from the moment I started my car until I shut it down. Unfortunately, this did not last more than the first few trips. Since then, the last 3 min segment does not get saved. I thought the firmware for the capacitor models was configured to delay shutdown for a second or two so the file could be written to the card as the capacitors deplete their energy. My unit shipped with fw 20150312, and I have tried both of @billknow 's latest (0318 and 0320), but the issue remains. Any advice?
Yes, only at shutdown when I power the car off. If I manually power off the dashcam, the last segment saves just fine.does the last file get corrupted at shutdown?
Thanks to my many months of reading this forum and the helpful advice of others, this was the first thing I did when I received the card. It's fine, and it was formatted only in the dashcam.Test your SD card with something like h2testw.
capacitors are faulty, contact the reseller about replacement/warranty
