- May 1, 2013
- Dublin
- Ireland
There will never be a fully perfect dash cam ( as with all technology ). People want always more and more and more. But from few dozens of dash cams I have tested ( half of them were so called premium class priced over 200usd ) - DOD LS300W video quality can be compared with high end models ( if not better in most cases ).
About cars numberplate readings ( reflection ) at night I want to start new tread, but I was not sure if it was discussed here yet or not ?
We can discuss this very important issue and each member can share his own experience / knowledge.
HID / XENONE Bulbs, NUMBERPLATE READINGS AT NIGHT:
At night, very important for numberplate reading will be two factors:
1. do you use standard bulbs or HID / Xenon. If standard bulbs, then numberplate readings are good from most angles. If HID / Xenon, then there will be a reflection from the front car numberplate till the moment when your lights will not shine exactly directly onto the front car numberplate.
2. If front car numberplate is on the white background ( like most European cars ), or on some other ( non-white ) background.
a) If white numberplate background, then it is very hard to read a number because direct HID / Xenon light will be bouncing back directly into your camera and overexposing whole car numberplate, so you will not be able to read numbers.
b) If non-white numberplate background, for example in UK cars have front numberplate background white, but rear numberplate background is yellow, so the reading of numberplate which are with yellow background is much better than if it would be white. The best cars numberplate to read / record if your car has HID / Xenon is for example Chinese cars where depending on province ( or some other factors ) they are using blue, green and black colour numberplate background. From those numberplate HID / Xenon light of your car bulbs is not reflecting that much ( not over-reflecting ), so reading is the best compare to EU car numberplate.
P.S. Using polarized filter on your dash cam at night can reduce front car numberplate reflection, so you can read it, but dramatically darkens everything what is around the car, it will be almost pitch-dark, in many cases you will not see even what car type / model it is, so polarized filters are no good to use for night driving.
This HID / Xenon reflection issue is common to all dash cameras no matter what price. It's just laws of combination: optics / cmos / cpu, which is hard to overcome within small price that today's dash cams cost. Only high-end professional movie cameras can sort out this issue, but they cost tens ( hundreds ? ) thousands of $.
Sorry for my english, but hope you know what I was trying to explain.
P.S. - thanks to DashCamMan to bounce my post into a new topic.
