iptelman
- Mar 29, 2016
- Canton, Ct
- DAB-202
Sure would be great if the firmware updates came with a change log. ![Cool :cool: :cool:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60e.png)
Not aware of this one. I'll ask and see if anything has changed.
Did you notice any new menu settings?Thank you @CaptureYourAction... I have flashed the v2534 yesterday... Haven't look at the videos yet...
OK, so I'm told the only thing that has changed in this latest version is the up/down buttons work a little faster while in playback mode.
Why not just use the .bin file?Hi, how can I update firmware to the latest with DirectUSB? Thanks.
No question it makes the colors pop.
The black road difference is amazing too.
Removing the CPL is easy if you find it makes the footage too dark at night. As far as the mount goes, as obvious as this sounds, really make sure that the mount is really tight into the camera. If you still have movement/vibrations then try the washer trick. Like in iptelmans picture, make sure the thumb wheel/nut is all the way up against the mount, then screw it down tight into the camera (with washer in between). I used a smaller washer than the one in the picture and it eliminated any movement I saw. I would think a larger washer (fender washer) would work even better.How about some night time footage?Wondering how'd it look with the CPL on. Also, what's this anti-vibration mod lol
5. I have read the forms and there has been many firmware updates to the camera. Can you turn the mph so it is not display in the video when using the GPS?
I just want to confirm some functions of the Dome D201. Motion Detection, Parking Monitor features.
1. Does the motion detection turn the camera on when the car is parked and power is off to the camera?
2. Will it use the internal battery to capture video until motion is not detected?
3. Will the Parking Monitor feature work with the power off to the camera and use the internal battery?
4. How long will the battery last that is built into the camera?
@Falsificator has increased the bitrate of an older version. He had it up to around 40 I think. Not sure if he's done anything with the recent version, but I think I still have a copy of the old one if you want to try it. FYI, there is a newer version than 2535. 2771 is the latest, but there is no change in video quality.Is there a way to modify the bitrate of the latest firmware v2534_v4 ? Or is someone able to modify it and upload then? Thank you
