Hi. I bought this dashcam and I have a problem.
When car no drive movie is jumping:
Firmware is 3099Y, resolution 1980x1024 HDR
It seems to only appear when your stopped (car running). It did not appear to do this while your car was off, only when you started the car. Perhaps your getting some kind of electrical interference?
Looks like "Diesel Jello" to me. (Vibration artifacts)
I have the same problem with my Yi Dashcam,also in a diesel engine car,sometimes.
Looks like the mount is not tight.
Tighten the round screw mount.
I don't think this has anything to do with the mount. Though the mount isn't great on these. I have seen this same effect on a DOD camera. A user had this issue in his diesel truck. Only occurred when the truck was running and the camera ran fine when he used it in a different vehicle. Try it in a different vehicle and see if it still does it.
You are right that the engine is guilty. You know where I buy the camera holder (I use two cars and I do not want to change every time)? I prefer aliexpress, but ebay is fine too.
I believe Dome has changed the mounting design on the DAB201. They did this on the DAB205 awhile back. So, I'm not sure which style you have. The first link below is for an adhesive mount that should fit the original design (T-Slot). The second link will fit the newer design. Look at your camera to see which you have.
https://www.aliexpress.com/item/New...10037_10017_407_10033_406_10032_10040,searchw
https://www.aliexpress.com/item/New..._10151_10068_10130_10136_10137_10060_10138_10
I've seen a lot of videos before i buy this camera, DAB201. I'm not so happy with it until now because the colors are too...vivid, images are burned. Firmware is 3099.
Is this normal?
192x1080x60fps
2560x1440x30fpsx_HDR
2560x1440x30fpsx_No_HDR
Is this normal?
192x1080x60fps
Hi! Try v2135 hi bitrate, maby you will like. Good day!
It doesn´t matter what firmware i use, the images look absolutely the same, too much colors. With HDR enabled is not so colorful but still too much. Is this a sensor problem?
Maby your camera has a problem. Or you like life in black&white :))
