Ordered one but haven´t got it yet. Hope there will be fw and software updates soon as this product seems quite "pre production" version. What i have found is this:
http://www.tonmind.com/product/CarCamcorder/T1.asp
Should someone who already has this product ask for new updates from "austin" ?
Have gotten new version of TonView and GoView... It's much better than the first version. Lesser frame skip when watching live feed.
But I still managed to hang my mini0902 and it restarted itself when I tried to change more than 3 settings in the dashcam...
GoView 2.2.0.5 apk
https://dl.dropboxusercontent.com/u/83037195/GoView2.2.0.5.apk
TonView 2.2.0.1 apk
https://dl.dropboxusercontent.com/u/83037195/TonView2.2.0.1.apk
I saw GoView have offline maps by Baidu while TonView can use Google Maps...
How about Iphone app. Downloaded it from App Store and it says TonView 1.0.0 although Update History says: 1.0 : 31.1.2016 - 1.0.1 : 12.2.2016.
Something wrong with version history. Tried removing program and installing it again - still version 1.0.0 - Where did you get those Android software versions ?
Okay I received my Mini 0902 as well.
There are a lot of video's on the SD card, which can or cannot be played by WMP...
The app Tonview isn't very clear... You cannot see when it's recording or not (I think it always is).
And of course the image quality... It's not so good, certainly not for the sensor and chipset that it's using. It should do a lot better!
Will this be fixed by firmware upgrades? Or was this a way to make easy money?
This could do the Mini "brand" a lot of harm I think. Mini always was a reliable cam, for the image quality...
There is reset hole.@Sunny since the Mini0902 has no display and no physical power button, how do you do a factory reset?
I changed the default password on mine using TonView on my iPhone and WiFi no longer woks now. By that I mean the 0902 is no longer broadcasting its SSID. I want to restore it to factory settings but I have not been successful using the reset button on the unit. What is the trick? What am I missing?
Been there, done that. Tried multiple times holding it up to 30 seconds. Did not work.There is reset hole.
Use a pin or something to press it for around 10 seconds.
the reset hole is just a software reset, you're looking for a way to reset defaults
if you can get a copy of the firmware reloading it should put things back to normal, otherwise it might be able to be done by loading a text config file, I'm sure @Joy will be able to advise when she's back online next, if I see her tomorrow I'll mention it
S | New firmware for mini 0902 (20160616) | Mini 0902 | 1 | |
S | Default Wifi password for Mini 902 | Mini 0902 | 3 | |
Mini 0902 Review (GearBest) | Mini 0902 | 14 |
