Hmm... how does that work?I found a small hack. I chose the mode 2560x1080 using the program linkinEyes. The camera began to record video with high bit-rate (18Mbit)
PM me your email address and I will send it to youCan you send me new firmware update please?
I sent you a PM.I do not know how to PM my email to you, could you pls kindly explain how to PM you?
Thanks.I have prepared modified firmware for video recording with high bit rate. (2304 x 1296 x 18Mbit, 1920 x 1080 x 15Mbit)
https://www.dropbox.com/s/8g5heymje9l5e0u/Cardv-firmware-A755-1.2.2_18Mbit.bin?dl=0
PS: I am not responsible for any bricked devices
Has anyone found a way to turn off small video file generation? Seems like a waste of resources.
I wish the small files were saved only when wifi preview was being used.the small video files are for the wifi preview
Any idea when a new firmware version with some much needed performance improvements will be released?
How is your modified HBR firmware working out for you? Can you post some video?I have prepared modified firmware for video recording with high bit rate. (2304 x 1296 x 18Mbit, 1920 x 1080 x 15Mbit)
A few days tested the camera at home.How is your modified HBR firmware working out for you? Can you post some video?
For the firmware it is necessary to rename the firmware file to "firmware.bin" and copy it to formatted empty SD card. It is better to use a card formatted for FAT32. Insert the card into the camera and turn it on. Camera will restart after the firmware update.Also how can I update the fw?
Dps, thank you for the video. I will review it later today when I get home.A few days tested the camera at home.
The modified firmware works well. The camera will not become stronger bask by increasing the bitrate, as here someone was afraid. The test video can be downloaded here https://www.dropbox.com/s/ikvmtx9e4a2zea0/20160418190900.MP4?dl=0
S | New firmware for mini 0902 (20160616) | Mini 0902 | 1 | |
S | Default Wifi password for Mini 902 | Mini 0902 | 3 | |
Mini 0902 Review (GearBest) | Mini 0902 | 14 |
