I remade some images last night, here are three captures along the same street as I was moving. This is the entire frame as captured by the N5S camera along with a few inserts of plate captures and zooms. The overall scene capture is quite good, it is easy to see areas on both sides of the car for quite some distance down the road. Given the time of night, the sky was indeed black (cloudy day beforehand). The camera that each zoom came from is labeled in the image. In all cases, I selected the single best frame from the video stream for comparison. This is a pretty challenging setting with high contrast and fairly large speed differential (moving at 20-25 mph vs parked car).
N5S and N4S are 2.5k main cameras, the N4 Pro S and the A139 Pro are 4k main cameras, so it is not surprising that they fared a bit better due to the extra resolution, but the N4S with HDR and PlatePix did a pretty good job for a lower resolution camera! The N4 Pro S did the best job overall, rendering an easily readable plate with great contrast, no doubt a function of the PlatePix function!
N5S main camera overall scene #1: HDR/WDR enabled for all cameras, polarizer lens installed on all cameras, PlatePix enabled for N4S and N4 Pro S.
N5S main camera overall scene #2: HDR/WDR enabled for all cameras, polarizer lens installed on all cameras, PlatePix enabled for N4S and N4 Pro S. Again, the overall scene is well-rendered in terms of overall exposure.
N5S main camera overall scene #3: HDR/WDR enabled for all cameras, polarizer lens installed on all cameras, PlatePix enabled for N4S. This particular scene is a bit darker overall than the two previous images, I'm presuming the exposure for the N5S camera was influenced by the headlights and road reflection of the oncoming car.
The N4 Pro S was not in my car for this last comparison directly above and the third car that I was targeting had moved by the time I looped around, so I don't have a direct comparison for the N4 Pro S (bummer). It's challenging to make comparisons while trying to manage the settings and swapping out multiple cameras. Presently, I have four cameras across my front windshield... Despite the lower resolution, the N4S (2.5k resolution) with PlatePix did an admirable job in this situation. The A139 Pro is a 4k camera, so it's rendering is a bit sharper than the other two due to higher resolution, but it also exhibits less contrast which could make reading the plate a bit more challenging in other situations.
It seems that the Wide Dynamic Range setting of the N5S lags behind the HDR function of the N4S (both cameras are 2.5k) for night time scenes. My earlier posts (
Post #49 and
Post #65 and
Post #68) show an advantage for N5S's WDR over HDR of the N4S during bright sun of the mid afternoon. It's curious how each technology has it's "preferred" environment where it performs best. It seems cliche, but I keep thinking about that old phrase "There is such thing as a free lunch." There are tradeoffs everywhere, so it's up to you to determine which characteristics are important and fit your driving pattern.
The N5S is an excellent performer if you are looking 4 channel capability, as it provides a good view out the side windows from the front and rear interior cameras. This is especially well suited for parking mode at shopping centers or at work. The exteriors cameras, of course, do a great job capturing what they should in front of and behind the car. The N5S performs best during normal daytime driving, rendering plates and overall scene capture a bit better than the N4S. If you do very little night time driving and/or value the 360 degree video coverage, this is an excellent choice! If you are a night time commuter and don't need the 360 degree coverage for parking mode, the N4S or N4 Pro S could be a better choice for you.
And still one of my favorite features, with the most recent firmware updates, BOTH the N5S and the N4 Pro S cameras retain their original date stamps when copying files from the SD card to your computer, so finding the footage you are looking for is easier and more intuitive! Next, I want to play with some of the new menu options for parking mode that are intended to prevent false positives when you get back in the car at the end of the day.
