Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
The new GitUp frame has clearance for everything, except that when mounted the right way up for tripod use half the top LED is covered, still perfectly visible though, and you need to remove the camera from the frame to change the battery. It is a very nice frame, easy to get the camera in and out without dismantling anything, or even unplugging anything and holds the camera well.
The remote doesn't talk wifi, although I think it broadcasts on the same frequency, just a different protocol.
I suggest you install the September firmware, it is easy to install and gives a useful update. There have only been minor improvements since, will be worth installing when available though.will try that september firmware unless this new one comes out soon. screen off while charging will be nice, as that white screen is pretty bright.
is the watch remote waterproof? it kinda looks like it would be since it's almost entirely made of rubber. i haven't taken off the back cover to see if there's an o-ring to seal it like a normal wristwatch.
Remote is surf proof, not diving proof.
