that certainly eliminates the window tint problemSo, a waterproof rear camera be a better solution when outside installation!
I agree! The sooner we can get such an option for B4K, the easier I can recommend it to all the sedan car owners (nowdays the rear glass is very sloped, at night the glare is terrible so not much information can be recorded).So, a waterproof rear camera be a better solution when outside installation!
it's not, was never promoted as being one eitherI think rear camera is not a starvis sensor.
ok yes , quality is terrible on rear camera, at night especially. I would be happy to pay to upgrade rear to starvis. No complaints with Front camera is great. Here is the morning front camera footage, I do need to get CPL filter.it's not, was never promoted as being one either
It is a GC2053 sensor; We do not use this IMX307/IMX291 due to high cost;I think rear camera is not a starvis sensor
it would be great to offer B1W as rear addon at same cost as B1W ,ie intergrate with b4k existing wiring.It is a GC2053 sensor; We do not use this IMX307/IMX291 due to high cost;
not something you can just plugin like thatit would be great to offer B1W as rear addon at same cost as B1W ,ie intergrate with b4k existing wiring.
no, they would always be two independent cameras with separate wiring and memory cards, nothing stopping you from using a B1W as a standalone rear camera though, others have used them like this before and been happy with the resultswould it possible to wiring b4k and b1w from same hard wiring kit?
good idea. i may hardwire b1w as rear camera with second hardwiring kit.no, they would always be two independent cameras with separate wiring and memory cards, nothing stopping you from using a B1W as a standalone rear camera though, others have used them like this before and been happy with the results
B1W about AU $80 dollars, I will look for a better rear camera for B4K if you can afford it lol...it would be great to offer B1W as rear addon at same cost as B1W
A better sensor will improve!an the bitrate be improved on the rear camera>
yeah like b2k or another b4k lol i wonder how much parking mode hours it would give me then lolB1W about AU $80 dollars, I will look for a better rear camera for B4K if you can afford it lol...
When I was reviewing the BlueSkySea B4K camera, I had to figure out why it would not go into parking mode. It turned out I was sent the incorrect hardwiring adapter. When I received the correct hardwiring adapter, it had this second switch with no documentation. I tested both positions left/right and found that the left position is the one that makes that power adapter compatible with the B4K parking mode requirements.Also the HWK had a tiny recessed switch to select parking guard signal mode. The documentation is value about this, and there's no indication which position was for what. So I struggled to figure out which position worked with the B4K for parking mode and which didn't. I _think_ I have it figured out (slide to left) - (looking at the HWK body with voltage selector on right, and parking signal mode switch to the left).
