Hi dashcam users,
I am the owner of a SG9663DC with 3 wire adapter connection. The parking mode is not working (as expected).
I set the threshold to cutout power at 11.8V and shutdown timer to 24h (I tested also with 18h). I used 2FPS for parking mode.
0. This timer will turnoff the camera when parking mode is enabled? - I don't understand what is the usage intent for this timer.
1. why "27. Change - Remove motion detect to enable Parking Monitor function"? I think is a good feature.
2. my dashcam only record for about 2h - 4h after car is turned off. I plan to debug this in order to understand why recording stops.
2.1. Doesn't anyone know what accuracy has the 11.8V detection threshold?
2.2. If I open the files with Dashcam software (MAC) do you have log that will tell my why camera turned off.
2.3. Do you have a way to enabled 'DEBUG MODE' that will save more logging information related to important events (turned on / turned off / parking mode ... and so on).
two night before I checked the settings for the dashcam and (due to some unknown reason) the parking mode didn't kick in when I removed the keys. So camera recorded all night with 30FPS. I don't know for sure the sequence of events (to duplicate this problem) but for i remember I didn't turn on the car ... I only applied power for about 30 sec (turned keys half ways) and check settings in the menu and removed the keys.
2.4. last step ... probably I should check that car doesn't turn off the 'sunroof fuse' after sometime. But taking into account that recording lasts for a variable time (and recorded whole night few days a go) -- I consider this very unlikely . but should be verified anyway
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
other info:
I leave in California so during night time the temperature goes down to about 10C / day about 25C
I have a Camry 2015 LE (adapter connected to sunroof fuse + 12V socket fuse)
Thank you,
Alin
