Recommended is 3 or 5Amp. If you use add a circuit adapter, then you can use any ACC fuse from car circuit pount, but for dashcam circuit use 3 or 5 Amp.What amp fuse should we use with this kit?
Thank you!Recommended is 3 or 5Amp. If you use add a circuit adapter, then you can use any ACC fuse from car circuit pount, but for dashcam circuit use 3 or 5 Amp.
NB! Never use Airbag fuse. Also alarm / immobilizer / central locking fuse is not recommended to use.
Thank you!
Note:
if you want to use SG in parking mode for motion detection and / or g-sensor recording, then you need to hardwire (+) to the constant live fuse, but again, - avoid airbag and alarm / immobilizer / central locking related fuses.
"I understand" (ten-four)10-4 = 6.
What does it mean "10-4" ?
Jokiin, I've done this.Buy a female lighter socket, connect that to your fusebox and plug the included adapter in, very simple and won't give you any warranty hassles
I plan to plug the positive into an ignition-only fuse, but my question is... where do I plug in the negative wire??
Ty
Is there anywhere in particular near the fuseboard that is an earth wire, as opposed to earthing to the bodywork?it needs to be earthed of course
How is it looking for you to do that video and review?Im hoping to have a video on hard wiring the SG with the cellpower kit, pier28 was kind enough to send for my testing/review.
Just finished hardwiring my SG9665GC (sold by pier 28 via Amazon) to my 2015 Nissan Rogue using the Cell-Power hardware kit from Pier 28 (bought via Amazon) and so far everything seems to be working. Just finished the install last night so I'll be testing it over the weekend.
Just bought the correct add a circuit from autozone, added a 5amp fuse and tapped into a spare 10amp fuse that's powered when the ignition is turned on.
